Sky Full of Heat
Old November 12th 12, 04:32 PM posted to rec.aviation.soaring
Andy[_1_]
Default Sky Full of Heat
Is that title a result of a bad translation to English? I wonder if
"Sky Full of Thermals" was intended. Hope not, or the rest of the
book could be a difficult read.
Andy
Old November 12th 12, 07:56 PM posted to rec.aviation.soaring
Andy
It’s an anagram, definitely not a bad English translation.
Old November 13th 12, 11:18 AM posted to rec.aviation.soaring
Andy
heat = Żar, but not only
some pictures related to the Żar
https://www.google.pl/search?q=%Żar...w=1280&bih=692
Old November 13th 12, 05:36 PM posted to rec.aviation.soaring
Andy[_1_]
I tried an on-line anagram generation tool and could find no
meaningful results. What anagram did you assume was intended?
Andy
Old November 13th 12, 05:42 PM posted to rec.aviation.soaring
Mike the Strike
Maybe it's a Palindrome?
Mike
Old November 14th 12, 12:45 AM posted to rec.aviation.soaring
- Heath of the moment, heath of the competition, heath of the thermals, but also heath of the atmosphere at the place he flies from which also happen to share the same name. Based on the fragments published on the facebook - both Polish and English, it certainly wont easily translate-able piece of work, but I don't think anyone expected: "landings made easy" from him...
Best,
Old November 14th 12, 12:47 AM posted to rec.aviation.soaring
- Heath of the moment, heath of the competition, heath of the thermals, but also heath of the atmosphere at the place he flies from which also happen to share the same name. Based on the fragments published on the facebook - both Polish and English, it certainly wont be easily translate-able piece of work, but I don't think anyone expected: "landings made easy" from him....
Best,
Old November 13th 12, 04:29 PM posted to rec.aviation.soaring
Wojciech Scigala
It was. The Polish title is "sky full of Żar", while Żar is
Sebastian's home airfield and one of centre mountain gliding points in
Poland. "Żar" is the name of the airfield and mountain, and it also
means "heat" in plain language. It was impossible to translate the title
perfectly.
WojtuÅ›
Old November 13th 12, 04:51 PM posted to rec.aviation.soaring
Bill D
perfectly.
WojtuÅ›
The title works for me if you accept "heat" = "energy". All atmospheric phenomena, especially that we call "lift", is driven by heat energy.
Old November 13th 12, 04:57 PM posted to rec.aviation.soaring
On Tuesday, November 13, 2012 10:51:42 AM UTC-6, Bill D wrote:
On Tuesday, November 13, 2012 9:30:02 AM UTC-7, Wojciech Scigala wrote: Użytkownik Andy napisał: Is that title a result of a bad translation to English? I wonder if "Sky Full of Thermals" was intended. It was. The Polish title is "sky full of Żar", while Żar is Sebastian's home airfield and one of centre mountain gliding points in Poland. "Żar" is the name of the airfield and mountain, and it also means "heat" in plain language. It was impossible to translate the title perfectly. -- Wojtuś The title works for me if you accept "heat" = "energy". All atmospheric phenomena, especially that we call "lift", is driven by heat energy.
+1
Thought it was a very elegantly stated title considering that one of the primary goals of any sailplane pilot is to find pockets of rising heated air to stay aloft. A world champion pilot exploiting the sky full of heat is perfect.
How does sun heat the air? [email protected] Soaring 47 December 21st 17 04:10 AM
Feel the Heat Maple1 Aviation Photos 0 August 2nd 07 07:07 PM
But it's a dry heat.... Casey Wilson Piloting 31 July 23rd 05 10:09 PM
Radio protocol regarding full stops on full stop only nights Ben Hallert Piloting 33 February 9th 05 07:52 PM
Pre-Heat at BED? Colin W Kingsbury Owning 7 January 21st 05 02:25 AM
