New Class for US Nationals
Old November 14th 12, 07:32 PM posted to rec.aviation.soaring
Paul T[_4_]
Default New Class for US Nationals
At 15:02 14 November 2012, John Cochrane wrote:
On Nov 13, 10:26=A0pm, wrote:
Your proposal may be the best way to go. Who can say for sure? But
after
all this discussion, it's still not clear to me why the US should go
outsid=
e the existing FAI rules.
As a Club Class competitor, I'd really be chapped to know the pilot who
b=
eat me and made the World Team was flying a sailplane not qualified to
fly
in the Worlds.
How will you feel when you drive all the way across country to the
sports class contest, and then get sent home because 8 people with
just the right gliders didn't show up? Ask the PW5 guys how this
feels.
How would you feel, if you were a new pilot, flew a regionals, found
this great ship to buy, went to club nationals, but they sent you home
because your ASW20B, Schweitzer 1-35, HP 18 or American-made
sparrowhawk isn't on a list maintained by a commission of
international volunteers that meets once a year in Switzerland?
How would you feel if 10 gliders showed up, but 3 of them were like
that, so everybody got sent home?
How would you feel if you got sent home, but then they release the
club class list for Finland, and your ASW20 B is now on it?
The FAI rules are designed to run club class world contests, in
Europe, based on gliders available at European clubs. There is no
reason to expect those rules to work for the US.
SSA, please give this a good hard look.
I can assure you, days and days have been spent looking at this,
looking through all the angles, reviewing the turnout data from all
the club class regionals, thinking through all the ways that bright
ideas can blow up.
John Cochrane
John your lack of understanding confounds me- IGC Club class is defined by
a handicap/performance range (which the 20b, ventus and LS6 are not in) -
not a list of gliders - the IGC list can be added to if the glider falls
within that handicap / performance range and is competing in a championship
i.e. a Slingsby Vega is not on the IGC list but could be added to it as it
falls within the handicap range used. That range of handicaps has been
fairly static for a number of years and has not changed at every
championship as you seem to state. Thus a 1-35 and HP18 would probably fall
within that range -a Sparrowhawk I doubt.
Your analogy with PW5 Class is entirely bogus as there are vastly superior
numbers of potential club class ships out there, even in the US.
Does lack of numbers stop you running an Open class comp?
Old November 14th 12, 10:33 PM posted to rec.aviation.soaring
Markus Graeber
Just to clear up some misconceptions with regards to the IGC Club class definition. From the current FAI sporting code (http://www.fai.org/igc-documents):
START QUOTE
FAI Sporting Code
Section 3 – Gliding
CLASS D (gliders)
including Class DM (motorgliders)
Chapter 6
GLIDER CLASSES and
INTERNATIONAL COMPETITIONS
6.2 HANDICAPPING
The purpose of handicapping shall be to equalise the performance of competing gliders as far as possible. The handicap values used shall be directly proportional to the expected cross-country speeds of gliders in typical soaring conditions for the competition concerned.
If handicapping is to be used, it shall be applied directly to the speed or distance achieved: for finishers, to the speed only, for non-finishers, to the distance only. Competitors completing the task shall not be given less than full distance points, and competitors not completing the task shall not
be given more than full distance points. Any list of handicaps proposed for a competition must be approved by the IGC.
6.5.8 Club Class
The purpose of the Club Class is to preserve the value of older high performance gliders, to provide inexpensive but high quality international championships, and to enable pilots who do not have access to gliders of the highest standard of performance to take part in contests at the highest levels.
a. ENTRY The only limitation on entry of a glider into a Club Class competition is that it is within the agreed range of handicap factors for the competition.
b. BALLAST Disposable ballast is not permitted.
c. SCORING Championship scoring formulas shall include handicap factors.
d. WING LOADING Wing loading shall not exceed 38 kg/m2.
FAI Sporting Code
Annex A to Section 3 – Gliding
RULES FOR WORLD AND CONTINENTAL
SOARING CHAMPIONSHIPS
CLASS D (gliders)
Including Class DM (motorgliders)
1.3 CHAMPIONSHIP CLASSES
1.3.1 The Championships shall consist of the one or more classes as described in the main body of Section 3 of the Sporting Code, Chapter 6, and as listed in the Local Procedures.
4.2 MAXIMUM TAKE OFF MASS
4.2.1 The following Maximum Take Off Mass (MTOM) shall be enforced:
d. Club Class – No ballast permitted and MTOM limited to the lowest of:
1. Maximum wing loading 38 Kg/m2
2. Maximum certified Take Off Mass without water according to Type Certificate Data Sheet (TCDS).
8.2 COMMON RULES
8.2.4 Handicaps
Handicapping shall be used in the Club Class and may be used in the 20 metre Multi-seat Class in Continental Championships only. Organisers shall state in the Local Procedures if Handicapping is to be used in the 20 metre Multi-seat Class.
a. Handicaps shall be taken from the valid IGC Handicap list or any other list approved by the IGC Bureau for the specific Championships.
b. The Organisers shall publish a list of all competitors with their handicaps before the beginning of the Championships.
c. Handicaps shall be applied according to 8.3.2.
Appendix 3
IGC Handicap Lists
The IGC Handicap Committee is responsible for the evaluation, review and publication of glider handicaps. The IGC Handicap lists consists of:
IGC Club Class Handicap List
IGC 20 metre Multi-seat Class Handicap list
The handicaps for each class are published on the FAI website.
http://www.fai.org/fai-documents
Effective date for changes to the handicap list is April 1st each year.
General rules for the IGC Club Class:
Only Single Seat Gliders with a handicap index of 1,09 or lower are eligible.
Retrofitting a glider with retractable landing gear increases the Handicap by 0.02.
Retrofitting a glider with winglets increases the Handicap by 0.01.
The pilot is responsible for providing documentation to prove that his glider will be operated within the legal weight limits.
The handicap is based on the performance at a stated glider reference weight, which is based on a typical empty weight plus 110 kg. Where a glider is flown at a higher weight by necessity, the handicap will be increased by 0.005 for each 10 kg or part thereof that the glider exceeds the base handicap weight.
General rules for the IGC 20 metre Multi-seat Class Handicap list:
To be determined.
END QUOTE
The current official handicap range used by the IGC is 0.96 to 1.09 (see http://www.fai.org/downloads/igc/IGC...bClassList_V1). The last handicap range change was in 2006/2007, when the top limit was moved up from 1,07 to 1,09. This led to the addition of ASW 20 WL (15m), Discus 1, ASW 24 WL/24B WL, DG 400 (15m), SZD 55 and ASW 20 (15m) to the official IGC Club class handicap list.
Now the not so obvious actual implementation of the Club class: Have a look at
Section 3 - 6.5.8 Club Class - a. ENTRY The only limitation on entry of a glider into a Club Class competition is that it is within the agreed range of handicap factors for the competition.
and then at
Annex A to Section 3 - 8.2.4 Handicaps
Handicapping shall be used in the Club Class ...
So yes, the official IGC Club Class handicap range is 0.96 to 1.09 but if the glider of your choice is ostensibly within that range but not on the official IGC Handicap list you are out of luck for a Category 1 event (Worlds/Continentals)... Unless the IGC has approved a different list for the particular you want to fly in...
This is the case for the 2012 Club Class WGC in Argentina this January, see http://www.fai.org/downloads/igc/IGC...ap_list_ARG_V2. They did not change the handicap range but did add the Std. Astir G102 & SZD-51 Junior to allow these gliders types to participate (even decent Club Class gliders are of limited supply in Argentina).
This illustrates the point that unless the glider of your choice is by name on an approved IGC Club Class handicap list (general or event specific) it won't matter if it falls within the predefined range, it won't be allowed to participate in an FAI/IGC Category 1 event.
The IGC maintains a very short handicap list that only includes the most common glider types in that handicap range, 51 total but in reality only some 15 or so truly different glider types. The current list is, as mentioned, Eurocentric with not a single non-European type on it.
At the 3 previous South American Continental Championships in Argentina 8.2..4 a. was used to approve the Argentine Handicap system to run 3 handicapped classes of distinct handicap ranges, have a look at the results from the last one this past January:
Standard Class - http://igcrankings.fai.org/CompPage.php?compid=1436
15m Class - http://igcrankings.fai.org/CompPage.php?compid=1437
Open Class - http://igcrankings.fai.org/CompPage.php?compid=1438
As you can see the glider list for Std/15m looked more like a Club Class list, this was a fully sanctioned FAI/IGC Continental Championship (Category 1) to which the full FAI/IGC sporting code (competition rules) applied.
Markus Graeber
IGC Delegate - Colombia
Old November 14th 12, 10:37 PM posted to rec.aviation.soaring
Markus Graeber
Link to South American Continental Championship Standard Class results got chewed up:
Old November 14th 12, 10:51 PM posted to rec.aviation.soaring
Markus Graeber
To put the handicaps into perspective, the IGC list is generally based on the German handicap list which includes pretty much anything flying incl. ETA, EB-29 etc. If the rest of the ASW 20s and the Ventus 1 were to be included in the IGC list they would likely get a 1.10, the LS-6 a 1.11, not an earth shattering extension of the current IGC handicap top of 1.09... Latest generation 15m ships would likely be in the 1.14 range...
Markus
Old November 16th 12, 08:27 PM posted to rec.aviation.soaring
Mike I Green
Marcus,
I don't think it is fair to bring facts into this argument. Shame on you.
MG
START QUOTE
FAI Sporting Code
Section 3 – Gliding
CLASS D (gliders)
Chapter 6
GLIDER CLASSES and
6.2 HANDICAPPING
6.5.8 Club Class
FAI Sporting Code
CLASS D (gliders)
8.2 COMMON RULES
8.2.4 Handicaps
Appendix 3
IGC Handicap Lists
To be determined.
END QUOTE
and then at
At the 3 previous South American Continental Championships in Argentina 8.2.4 a. was used to approve the Argentine Handicap system to run 3 handicapped classes of distinct handicap ranges, have a look at the results from the last one this past January:
Markus Graeber
Mike I Green
Day 3 at U.S. Sports Class Nationals Frank Paynter[_2_] Soaring 2 May 8th 11 12:50 AM
Sports Class Nationals John Godfrey (QT)[_2_] Soaring 0 June 25th 10 02:56 PM
Location of 2006 US 18m nationals and Sports Class Nationals and 15m ? John Bojack Soaring 2 July 18th 05 02:45 PM
US Standard Class and World Class Nationals at Hobbs Ken Sorenson Soaring 7 July 16th 04 04:03 AM
UK Open Class and Club Class Nationals - Lasham Steve Dutton Soaring 0 August 6th 03 10:07 PM
