CAI302 Push/Pull Arrows Missing
Old November 23rd 12, 10:34 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default CAI302 Push/Pull Arrows Missing
On 11/23/2012 2:01 PM, Darryl Ramm wrote:
On Friday, November 23, 2012 12:30:04 PM UTC-8, Jeff Casto wrote:
My CAI302 was intermittently turning off in flight, so my sailplane
partner
took it apart and found some loose connections. This fixed the
problem, but
now the push/pull arrows are missing from the display. The audio
works
fine. I'm sure this is a setting, but I can't find it. Can anyone
help?
Thanks,
If the C302 is really working all except the LCD push/pull arrows
then I would return it to Cambridge, but I'd carefully exclude more
other things first...
If Darryl's suggestions don't help, I'd suggest the connections between
the LCD and the circuitry did not get properly put back together.
email me
Old November 23rd 12, 10:52 PM posted to rec.aviation.soaring
Jeff Casto
Thanks for all the helpful replies. I'll check the items listed. WRT
security, it was out of cal. We plan to send it for cal in January. Is the
security reset then, or do we need to send it to Cambridge for that?
Thanks, again.
Jeff
partner
problem, but
works
help?
Thanks,
email me
Old November 24th 12, 02:11 PM posted to rec.aviation.soaring
Paul Remde
Hi Jeff,
I'm a Cambridge dealer and authorized agent for them. I can reset the
security on the 302 with help from Cambridge. I can also recalibrate it.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
____________________________________
"Jeff Casto" wrote in message
. com...
Thanks, again.
Jeff
partner
problem, but
works
help?
Thanks,
email me
CAI302 bent control knob Walter Weir Soaring 7 December 21st 10 02:52 PM
Push-Pull propeller combinations. Eunometic Naval Aviation 19 September 4th 10 07:25 PM
CAI302 altitude in NMEA.. PCool Soaring 6 October 23rd 09 07:25 PM
Red Arrows RIAT 07 - File 1 of 1 - Red Arrows RIAT07_web.jpg (1/1) RobG Aviation Photos 0 June 15th 08 12:59 AM
Question about center-line push-pull engine configuration Shin Gou Home Built 4 June 7th 04 05:57 PM
