Hi Jeff,
I'm a Cambridge dealer and authorized agent for them. I can reset the security on the 302 with help from Cambridge. I can also recalibrate it. Best Regards, Paul Remde Cumulus Soaring, Inc. ____________________________________ "Jeff Casto" wrote in message . com... Thanks for all the helpful replies. I'll check the items listed. WRT security, it was out of cal. We plan to send it for cal in January. Is the security reset then, or do we need to send it to Cambridge for that? Thanks, again. Jeff At 22:34 23 November 2012, Eric Greenwell wrote: On 11/23/2012 2:01 PM, Darryl Ramm wrote: On Friday, November 23, 2012 12:30:04 PM UTC-8, Jeff Casto wrote: My CAI302 was intermittently turning off in flight, so my sailplane partner took it apart and found some loose connections. This fixed the problem, but now the push/pull arrows are missing from the display. The audio works fine. I'm sure this is a setting, but I can't find it. Can anyone help? Thanks, If the C302 is really working all except the LCD push/pull arrows then I would return it to Cambridge, but I'd carefully exclude more other things first... If Darryl's suggestions don't help, I'd suggest the connections between the LCD and the circuitry did not get properly put back together. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me |
CAI302 bent control knob | Walter Weir | Soaring | 7 | December 21st 10 02:52 PM |
Push-Pull propeller combinations. | Eunometic | Naval Aviation | 19 | September 4th 10 07:25 PM |
CAI302 altitude in NMEA.. | PCool | Soaring | 6 | October 23rd 09 07:25 PM |
Red Arrows RIAT 07 - File 1 of 1 - Red Arrows RIAT07_web.jpg (1/1) | RobG | Aviation Photos | 0 | June 15th 08 12:59 AM |
Question about center-line push-pull engine configuration | Shin Gou | Home Built | 4 | June 7th 04 05:57 PM |
