Did Nano create an IGC file or did Oudie create one? please send such file to support at naviter dot com - it must be an easy settings fix. Or even just a matter of a firmware upgrade on any or all devices.
Regards, Andrej Kolar -- glider pilots use http://www.Naviter.com On Monday, November 26, 2012 3:10:58 AM UTC+1, Dan wrote: I'm flying with a V7/Nano/Oudie combination, I was wondering if anyone else had problems with this setup making Igc files when the set up is turned on and then off with out moving the plane. Dan |
On Sunday, November 25, 2012 11:55:17 PM UTC-8, Naviter Info wrote:
Did Nano create an IGC file or did Oudie create one? please send such file to support at naviter dot com - it must be an easy settings fix. Or even just a matter of a firmware upgrade on any or all devices. Regards, Andrej Kolar -- glider pilots use http://www.Naviter.com On Monday, November 26, 2012 3:10:58 AM UTC+1, Dan wrote: I'm flying with a V7/Nano/Oudie combination, I was wondering if anyone else had problems with this setup making Igc files when the set up is turned on and then off with out moving the plane. Dan Andrej, It was the Oudie that created the file. All devices are running the latest firmware. If you don't recall I sent you a file back in March of this year, to which you responded "this will take some time". I waited 3 months, and sent a follow up email to check on progress, to which you responded," please send me a file" which I did. Then I was told this would not be addressed until sometime next year. (I'm not holding my breath) Regards,Dan |
Looking for a wiring diagram for the LXNAV V7 to Oudie cable. I tried following the diagrams in the V7 manual but did not have success even using a proto board to try different configurations.. The offical cable I have has five wires rather than the four that the diagrams show. I would like to build cables for a pass through connection in the panel.
On Monday, November 26, 2012 8:20:56 PM UTC-8, Tim Taylor wrote:
Looking for a wiring diagram for the LXNAV V7 to Oudie cable. I tried following the diagrams in the V7 manual but did not have success even using a proto board to try different configurations.. The offical cable I have has five wires rather than the four that the diagrams show. I would like to build cables for a pass through connection in the panel. Check your email for the cable drawing. Don't get dyslexia you may brick the stuff. Richard www.craggyaero.com |
Help please!
I am unsuccessful at updating my V7 with the latest 3.02 software. (I did successfully upgrade to v2.02 two years ago). I am trying to update with my PNA Vertica V2. Part of the problem is that I am not sure which COM port to select from the PNA V2. Here's the combination of errors that I get: COM1: "Load" message appears, but the "Discovery" message does not. I then get this error window pop up: "Update failed, error code = -5" COM2 or COM3: Load message appears, Discovery then starts but after 5 seconds, error window message: "Update failed, error code = -10" COM 4: Load message appears, Discovery then starts but stays stuck. When I eventually hit "cancel" on the PNA, the error message is: "Update failed, error code = -21" shows up. Additional info: - The baud rate is set at 115200 on both the V7 and the PNA (I have been forewarned about using anything else so I always triple check) - The LXNav "PNA Update tool" and firmware are the latest versions from the LX website What I am screwing up? Thanks, B |
On Saturday, February 22, 2014 11:28:10 PM UTC-6, Bastoune wrote:
Help please! I am unsuccessful at updating my V7 with the latest 3.02 software. (I did successfully upgrade to v2.02 two years ago). I am trying to update with my PNA Vertica V2. Part of the problem is that I am not sure which COM port to select from the PNA V2. Here's the combination of errors that I get: COM1: "Load" message appears, but the "Discovery" message does not. I then get this error window pop up: "Update failed, error code = -5" COM2 or COM3: Load message appears, Discovery then starts but after 5 seconds, error window message: "Update failed, error code = -10" COM 4: Load message appears, Discovery then starts but stays stuck. When I eventually hit "cancel" on the PNA, the error message is: "Update failed, error code = -21" shows up. Additional info: - The baud rate is set at 115200 on both the V7 and the PNA (I have been forewarned about using anything else so I always triple check) - The LXNav "PNA Update tool" and firmware are the latest versions from the LX website What I am screwing up? Thanks, B Bastoune- your v2 needs to use COM7 for the PNA update tool to talk to the v7 and that is not available from the pulldown. You will need to bring up a keyboard on your v2 and type in COM7 and I think it will work - at least it does from my Avier. Mike O. |
On Sunday, February 23, 2014 9:04:39 AM UTC-5, wrote:
On Saturday, February 22, 2014 11:28:10 PM UTC-6, Bastoune wrote: Help please! I am unsuccessful at updating my V7 with the latest 3.02 software. (I did successfully upgrade to v2.02 two years ago). I am trying to update with my PNA Vertica V2. Part of the problem is that I am not sure which COM port to select from the PNA V2. Here's the combination of errors that I get: COM1: "Load" message appears, but the "Discovery" message does not. I then get this error window pop up: "Update failed, error code = -5" COM2 or COM3: Load message appears, Discovery then starts but after 5 seconds, error window message: "Update failed, error code = -10" COM 4: Load message appears, Discovery then starts but stays stuck. When I eventually hit "cancel" on the PNA, the error message is: "Update failed, error code = -21" shows up. Additional info: - The baud rate is set at 115200 on both the V7 and the PNA (I have been forewarned about using anything else so I always triple check) - The LXNav "PNA Update tool" and firmware are the latest versions from the LX website What I am screwing up? Thanks, B Bastoune- your v2 needs to use COM7 for the PNA update tool to talk to the v7 and that is not available from the pulldown. You will need to bring up a keyboard on your v2 and type in COM7 and I think it will work - at least it does from my Avier. Mike O. Has anyone accomplished this update with a MIO? I have my MIO connected to the V7 via the Glider Tools cable but have not attempted a firmware update via this connection. Lane |
Can someone post the wiring diagram to connect the Vertica V2 / Avier to the V7?
Thank you, Nick |
On Monday, June 2, 2014 11:10:33 PM UTC-7, wrote:
Can someone post the wiring diagram to connect the Vertica V2 / Avier to the V7? Thank you, Nick Google "glider guider USB/Serial Data Interface" There's a PDF that has the pinouts for the GliderGuider / Vertica V2. The pinouts for the V7 are available at the LXnav website in the V7 manual. I'm assuming you're using a separate GPS source for the V7. I'm not aware of a way to get the GPS data from the Vertica into the V7. Cheers, Craig |
Howdy. Has anybody had trouble getting the V7 to display glide info from the Oudie lately?
Thanks, Jim |
LXNAV V7 - Reviews? | David Reitter | Soaring | 10 | October 21st 14 12:41 AM |
New LXNAV LX9000 Overview Video | Paul Remde | Soaring | 0 | April 21st 12 01:33 AM |
LXNAV V7 | Paul Remde | Soaring | 2 | November 2nd 11 12:31 AM |
LXNAV Nano and LX 9000 Overview Videos Available | Paul Remde | Soaring | 3 | February 28th 11 01:58 PM |
HELP! Need offical Blanik L-13 Canopy Strap | John Scott | Soaring | 4 | March 3rd 08 05:03 AM |
