FAI (IGC) rules for US Club Class Nationals - Petition
Old November 27th 12, 11:54 PM posted to rec.aviation.soaring
Richard Walters
Default FAI (IGC) rules for US Club Class Nationals - Petition
Let's not forget what I consider the most unfair IGC CC rule of
all- no actual weight based handicapping. So if I fly a Discus b at
825 pounds and BB flies a Discus a at 700 pounds, we fly with
the same handicap. I would have a one pound PSF wing loading
advantage, which would be helpful anywhere but the maybe the
UK.
Big, heavy guys take note. I weigh 100 kg. BB considerably
less.
Richard Walters
At 23:13 27 November 2012, wrote:
I encourage you to review the rules. IGC is LESS
complex,simpler and
easier to understand. IGC rules are 15,091 words long
compared to 25,804
(US rules).
http://www.fai.org/igc-documents
Go to Sporting Code Section 3 Annex A
1. No 1-34s, etc. so we don't have to worry about low
performance
gliders when task setting.
YES
2. No LS-6s, Venti and ASW-20Bs&Cs.
No LS-6 or Venti. ASW-20B&Cs HAVE BEEN allowed. They are
specifically
excluded in Argentina at the next WGC.
3. No speed or altitude limits prior to the start.
Altitude limits are up to CD discretion, similar to US Rules.
4. Much more emphasis on ATs.
YES. There are ONLY Racing Tasks (AT) and Assigned Area
Tasks. 50/50
seems to be the philosophy.
5. Score everything according to FAI rules.
YES. See scoring calculations on page 31 & 32 of FAI SC3a
rules.
Sean Franke
Old November 28th 12, 12:13 AM posted to rec.aviation.soaring
UK.
less.
Richard Walters
The reference weight for Discus a & b is 367 kg. Every 10 kg incurs a handicap increase of 0,005. Yes, there can be a wing loading difference but it's accounted for in the handicap.
Copied from current handicap list:
"The handicap is based on the performance at the New IGC Reference Mass.
If a glider is flown at a mass not exceeding this reference mass it can be considered as operated within legal mass limits.
Where a glider is flown at a higher mass by necessity, the pilot will have to provide documentation to prove that his glider is
still operated within legal mass limits and the handicap will be increased by 0,005 for each 10 kg or part thereof that the glider
exceeds the reference mass. However the wing loading may in no case exceed 38 kg/m2. In addition the handicap may in no
case exceed 1,09."
Sean Franke
Old November 28th 12, 12:59 AM posted to rec.aviation.soaring
Richard Walters
Sean,
My understanding is that pilots that fly under the "normal" weight
for their glider type, do not get a handicap reduction. So instead
they fly with lead bars to get to the normal weight. Or they fly
light ( real light in the case of Sarah Arnold) and give up an
unfair advantage.
Are you proposing allowing lead ballast?
Richard Walters
of
b at
with
loading
UK.
less.
Richard Walters
incurs a
difference
Reference Mass.
mass it can be
will have
increased
no case exceed
case exceed 1,09."
Sean Franke
Old November 28th 12, 01:15 AM posted to rec.aviation.soaring
On Tuesday, November 27, 2012 4:59:56 PM UTC-8, Richard Walters wrote:
Sean,
unfair advantage.
Richard Walters
of
b at
with
loading
UK.
less.
Richard Walters
incurs a
difference
Reference Mass.
mass it can be
will have
increased
no case exceed
case exceed 1,09."
Sean Franke
You're right, there is no handicap adjustment for "under weight" gliders. I'm proposing mirroring IGC rules, handicaps and tasking philosophy.
Sean Franke
Club Class Nationals 5 ugly Soaring 37 September 24th 10 03:27 AM
US 15 Meters Nationals and Region V South Club Class [email protected] Soaring 0 March 12th 09 03:59 PM
Establishing Club Class/Too Many Nationals/Not Enough Competitors Tim[_2_] Soaring 14 October 2nd 08 03:34 PM
AUS Club Class Nationals Overall Results Mal Soaring 0 January 27th 06 09:55 AM
UK Open Class and Club Class Nationals - Lasham Steve Dutton Soaring 0 August 6th 03 10:07 PM
