World soaring contest logger requirements
Old December 3rd 12, 07:08 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Default World soaring contest logger requirements
On Dec 3, 1:48*pm, Ron Gleason wrote:
On Monday, 3 December 2012 10:55:15 UTC-7, Paul Remde *wrote:
Hi,
I received a question from a customer today that I couldn't answer. *He is
going to fly in the World Gliding Contest in Argentina soon and couldn't
figure out whether or not his Cambridge GPS-NAV would be acceptable to the
contest - since it is no longer approved for world records.
I can't seem to find anything in the Sporting Code for world contests - but
I didn't spend too long looking for it.
The customer has several other loggers that will work fine (LX7000 and LXNAV
Nano) - so the GPS-NAV should be a backup only.
Anyone have any idea about this?
I calibrated several loggers while at the World Gliding Contest in Uvalde,
TX in August, but I don't remember whether or not any of them were GPS-NAV
units.
Best regards,
Paul Remde
Cumulus Soaring, Inc.
Dan Daly replied and referenced the appropriate document, though in typical FAI fashion it is hard to find details. *It is up to the local organizers to state the approved FR. *If they do the same as in Uvalde then ...
go tohttp://www.fai.org/igc-documents
click on Free software for IGC file Validation & Downloading
click on IGC-Approved Flight Recorders - Approval Documents
click on IGC-approval Documents for all IGC-approved Flight Recorders
and you will be presented with the list that was updated 8 November 2012
I scored the Open Class at Uvalde and there was at least one pilot that used *GPS-NAV FR used for primary and secondary loggers.
Ron Gleason
And a fine job you did, Ron! Greatly appreciated by the dusty sweaty
masses!
DD
World Helicopter Aerobatic contest Stuart & Kathryn Fields Rotorcraft 0 August 24th 08 08:57 PM
world class contest [email protected] Soaring 0 July 23rd 08 05:38 AM
World Class PW-5 Contest at Marfa, TX Burt Compton - Marfa Soaring 13 June 22nd 06 07:00 PM
FAA lighting requirements for night soaring? Gary Boggs Soaring 5 December 21st 04 06:01 AM
World Champion Soaring Pilot To Speak at Sky Soaring John DeRosa Sky Soaring Chicago IL Soaring 0 May 14th 04 09:02 PM
