Power FLARM as logger
Old December 4th 12, 06:24 PM posted to rec.aviation.soaring
Ramy
Default Power FLARM as logger
Marc, I completely agree with everything you say (including starting final glide after sunset...). My grip is only on the requirement for the flight computer to be "certified". What's wrong with using SeeYou/XCSoar etc IGC files for badges and diplomas? I imagine much more pilots will be motivated to get their badges and diplomas if they could simply submit the IGC files from their flight computer, certified or not, just like OLC.
Ramy
Old December 4th 12, 07:05 PM posted to rec.aviation.soaring
FLARM
Ramy,
IGC 'Position Recorders' have been created for exactly this purpose; no certification required.
http://www.fai.org/gnss-recording-de...tion-recorders
Nobody seems to care enough to make it happen, except for some more or less random approvals (e.g. of non-IGC certified FLARM devices).
Urs
FLARM
Old December 4th 12, 09:01 PM posted to rec.aviation.soaring
Ramy, the approval process is only intended to provide some sort of reasonable baseline for the quality, integrity, and reliability of the evidence used to document flights that result in various kinds of FAI awards. We can argue about where the baseline should be, but if you eliminate the baseline altogether, in my mind, it starts to affect the value of the awards. GPS receivers are not all equal in quality, not all recording capable consumer GPS units produce usable position evidence, and code running on on readily reprogrammable devices isn't necessarily what it looks to be. We need some standards, which is not to say that existing standards are cast in stone.
Perhaps the IGC will eventually decide that SeeYou, XCSoar, or whatever, provide acceptable evidence on some specific kinds of hardware, but that is not the same thing as saying they will provide acceptable evidence on any and all possible hardware on which they run, which implies that there would still be a need for some sort of approval/certification process...
Marc
Old December 4th 12, 11:05 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
like OLC.
The problem is that some pilots have, both in the past and currently,
continued to cheat and fake logs. Even for 500 km flights. I don't
understand that mentality at all, let alone how they can live with
themselves knowing they are liars whenever they say they've earned the
badge.
But, as long as that sort is around, we need secure loggers and the whole
business of Official Observers and paperwork to stop them from devaluing
the badge and diploma system for the rest of us.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
US Power FLARM Antennas Andy[_1_] Soaring 13 June 21st 12 07:34 AM
Power FLARM deliveries? Andy[_1_] Soaring 1 June 5th 12 01:33 PM
Flarm data logger TMA Soaring 1 June 3rd 12 10:03 PM
Power FLARM question Kimmo Hytoenen Soaring 26 March 23rd 12 04:28 AM
Power FLARM portable reports? Andy[_1_] Soaring 2 December 9th 11 03:58 PM
