Gather local wind data
Old December 6th 12, 10:54 AM posted to rec.aviation.soaring
Anders Petersson
Default Gather local wind data
Hi again
I'm sorry I disappeared from the discussion. I thought I would get email notifications of new replies.
The technical solution has become more mature since September. It now supports humidity measurements. Radio range is much improved and testing will hopefully confirm support for altitudes of 7-9 km.
The weight is optimized to the point where 30 liters of helium should suffice. This makes a sounding very cheap as long as the electronics is recovered. We're looking into offering a variant for one-time use but haven't determined what pricing is possible yet.
As for alternatives, I don't see how a kite could measure winds and altitude is limited indeed. Results from a rocket would be inaccurate due to high vertical speed. In both cases, the payload can detach at peak altitude and take measurements while falling to the ground. That would mean the electronics still has to be retrieved some distance away.
A helium balloon is cheap but these other solutions would also work with Windsond. Approximate GPS coordinates of landing site together with loudspeaker, radio beacon and flashes of light makes it easy to recover.
We're now working to estimate the market to motivate production. In parallel, I'm doing development and testing. Your comments are valuable!
Regards
/Anders Petersson
Old December 6th 12, 05:35 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Good that you are making progress, Anders! Keep us posted!
Steve
Historical Wind Data for LKV? GARY BOGGS Soaring 6 November 23rd 11 03:34 PM
Fwd: Planets Gather on May 5 and May 17, 2000 [email protected] Owning 4 February 8th 09 02:40 PM
Fwd: Planets Gather on May 5 and May 17, 2000 [email protected] Piloting 5 January 27th 09 06:34 PM
Local Navy families gather in Sarasota Otis Willie Naval Aviation 0 December 24th 05 11:36 PM
