Ground launches and weak links
Old December 12th 12, 01:09 AM posted to rec.aviation.soaring
Bart[_4_]
Default Ground launches and weak links
On Dec 3, 4:56*pm, Brian wrote:
With the weak link at this level, you can not put more than 2g on the airframe.
Well Actually it is 3g since you have add the weight of the glider to it.
disclaimer type="I am not an aeronautical engineer; might not know
what I am talking about"
Won't it actually be even more that 3g? Something tells me that
lifting and non-lifting parts should not be treated in the same way
here.
/disclaimer
Bart
"Ground Launches" by Derek Piggott Randy Teel Soaring 1 August 9th 12 11:19 PM
"Ground Launches" by Derek Piggott Randy Teel Soaring 0 August 9th 12 10:10 PM
Use of weak links Paul[_7_] Soaring 64 June 8th 10 07:38 AM
Are Weak Links really Necessary for Aero Tow? [email protected] Soaring 41 September 19th 06 06:49 PM
Weak link for PW-5 Nyal Williams Soaring 4 June 1st 04 08:46 AM
