Butterfly iGlide App now available in the US
Old December 12th 12, 01:24 AM posted to rec.aviation.soaring
Sean F (F2)
Default Butterfly iGlide App now available in the US
http://www.butterfly-avionics.com/in...t-installation
Looks as if they might have some cycles started on developing some point integration. Integration, wireless, via Flarm would be fine. But I would like to see bluetooth integration methods from other modern, popular vario's such as the Butterfly vario, or LX V7. This should be possible...
Old December 12th 12, 01:49 PM posted to rec.aviation.soaring
Tobias Bieniek
From what I've heard Apple is not allowing the kind of Bluetooth connection (SPP) that is needed for virtual serial ports and that is the reason why Butterfly had to develop the wifi adapter.
Old June 2nd 14, 08:10 AM posted to rec.aviation.soaring
Can somebody from Butterfly verify or refute this? It would be nice not to have to spend twice as much for wifi when Bluetooth will suffice.
For that matter, why not a cabled solution? I expect many people will be using the Lightning connector for power already -- might as well send some data down that pipe, too.
Where are you Butterfly vario? [email protected] Soaring 17 May 25th 14 05:49 AM
Butterfly vario info [email protected] Soaring 1 August 7th 12 10:08 PM
Butterfly iGlide Reed von Gal Soaring 4 May 2nd 12 06:00 PM
New Butterfly Vario Paul Remde Soaring 238 February 20th 12 04:05 AM
This Just In- Butterfly [email protected] Soaring 6 February 17th 12 09:00 PM
