In article
, Mark IV wrote: World's fastest electric plane. (so far ) http://www.youtube.com/watch?v=rNAPLxZtoPg http://www.flightofthecentury.com/long-esa/ Motor-Trend, Car of the Year is Electric: http://abcnews.go.com/blogs/business...-motor-trends- car-of-the-year/ 400wh/kg is achieved: http://enviasystems.com/technology/ (They already know how to produce 1500wh/kg. It is forthcoming.) Thin-gap electric motors, Amazing: http://www.thingap.com/products/index.htm http://www.youtube.com/watch?v=y10o9...=results_video Other aviation electric motor specialties: http://www.yuneec.com/PowerMotor_Tech_spec.html Plane with built-in solar panels: http://inhabitat.com/elektra-one-sol...own-photovolta ic-charging-trailer/ (Actually, the entire surface...both top and bottom should be covered in photovoltaics) --- Mark "Everything will eventually be electric?" I don't think so! Unless someone can come up with something like the sci-fi "zero point module," "dilithium crystals" or some other means of storing large amounts of energy in small, lightweight packages, it won't. Batteries, which must store the equivalent of fuel *and oxidizer* will always be deficient here. For gasoline engines, the ratio is 15:1 by weight of oxidizer/fuel. It isn't the motors, but the energy source which fails. |
On 13/12/12 06:36, Orval Fairbairn wrote:
"Everything will eventually be electric?" I don't think so! Unless someone can come up with something like the sci-fi "zero point module," "dilithium crystals" or some other means of storing large amounts of energy in small, lightweight packages, it won't. Batteries, which must store the equivalent of fuel *and oxidizer* will always be deficient here. For gasoline engines, the ratio is 15:1 by weight of oxidizer/fuel. It isn't the motors, but the energy source which fails. And how would such a machine fit into an average fleet of training aircraft ? Most of the day it would be out either being recharged or having the battery pack replaced. And range. Any landings and refuelling away from base would have to take account of facilities at the destination.. At the moment it sounds far to complex to return revenue There was one electric powered aircraft in the 30s that looked great but could only fly circuits.. |
george152 wrote: On 13/12/12 06:36, Orval Fairbairn wrote: "Everything will eventually be electric?" I don't think so! Unless someone can come up with something like the sci-fi "zero point module," "dilithium crystals" or some other means of storing large amounts of energy in small, lightweight packages, it won't. Batteries, which must store the equivalent of fuel *and oxidizer* will always be deficient here. For gasoline engines, the ratio is 15:1 by weight of oxidizer/fuel. It isn't the motors, but the energy source which fails. And how would such a machine fit into an average fleet of training aircraft ? Most of the day it would be out either being recharged or having the battery pack replaced. And range. Any landings and refuelling away from base would have to take account of facilities at the destination.. At the moment it sounds far to complex to return revenue There was one electric powered aircraft in the 30s that looked great but could only fly circuits.. Did it have a very LONG extension cord? |
On 13/12/12 10:33, Orval Fairbairn wrote:
And how would such a machine fit into an average fleet of training aircraft ? Most of the day it would be out either being recharged or having the battery pack replaced. And range. Any landings and refuelling away from base would have to take account of facilities at the destination.. At the moment it sounds far to complex to return revenue There was one electric powered aircraft in the 30s that looked great but could only fly circuits.. Did it have a very LONG extension cord? ![]() No but it did have a very large lead battery |
On 12/12/2012 2:37 PM, george152 wrote:
And how would such a machine fit into an average fleet of training aircraft ? Training is all about economics, and the economics for battery powered aircraft (or virtually any new aircraft) for the training market simply aren't there...and may never be. Most of the day it would be out either being recharged or having the battery pack replaced. Not necessarily so. You could have quick change battery packs that presumably would take no longer to swap than it takes to refuel a plane. However, that would require multiple battery packs, so economics rears it's ugly head again. And range. Quickly improving. A few electric models are plenty good enough for sport use today. Any landings and refuelling away from base would have to take account of facilities at the destination.. As they always have... At the moment it sounds far to complex to return revenue Complex? Nonsense! Electric planes can be quite simple compared to an equivalent IC plane. Return revenue? You mean economics? That's another matter! It's actually the real issue, and perhaps the deal killer. There was one electric powered aircraft in the 30s that looked great but could only fly circuits.. Your point? |
Vaughn wrote:
On 12/12/2012 2:37 PM, george152 wrote: And how would such a machine fit into an average fleet of training aircraft ? Training is all about economics, and the economics for battery powered aircraft (or virtually any new aircraft) for the training market simply aren't there...and may never be. Most of the day it would be out either being recharged or having the battery pack replaced. Not necessarily so. You could have quick change battery packs that presumably would take no longer to swap than it takes to refuel a plane. However, that would require multiple battery packs, so economics rears it's ugly head again. And range. Quickly improving. A few electric models are plenty good enough for sport use today. Any landings and refuelling away from base would have to take account of facilities at the destination.. As they always have... At the moment it sounds far to complex to return revenue Complex? Nonsense! Electric planes can be quite simple compared to an equivalent IC plane. Return revenue? You mean economics? That's another matter! It's actually the real issue, and perhaps the deal killer. There was one electric powered aircraft in the 30s that looked great but could only fly circuits.. Your point? The real problem for for any vehicle application is charge time which is limited by basic physics and how much power you can get down a wire and through a practical connector. Say you have the equivelent electric airplane of your typical bug smasher that has 180 HP and runs at 75% power. Neglecting any losses and conversion efficiencies, which just make the numbers worse: That is 180 X .75 X 745.7 = approximetely 100 kW. If you fly for 3 hours you use 300 kWH. Assume the battery voltage is 100 V, which is a rather ballpark typical value for an electrical vehicle, you have to supply 3 kAH to charge the battery. If you want to charge the battery in a half hour, your cable and connectors must carry 6,000 Amps. Increase the battery voltage to 200 V and an hour charge time and you still have to carry 1,500 Amps. |
FS: Electric tow | Bug Dout | General Aviation | 0 | October 16th 10 06:27 PM |
Hawker Kestrel - led eventually to the Harrier | jd | Aviation Photos | 0 | April 25th 09 07:10 PM |
Where old planes go to die (eventually) | Kingfish | Piloting | 3 | May 14th 07 04:40 AM |
Electric DG | Robbie S. | Owning | 0 | March 19th 05 03:20 AM |
Electric Vehicle | sanman | Home Built | 3 | May 24th 04 07:08 PM |
