Lowering cockpit RF interference
Old December 14th 12, 07:33 PM posted to rec.aviation.soaring
Tom Gardner[_2_]
Default Lowering cockpit RF interference
Hello all EEs.
What is standard operating procedure for when and where to use shielded wire in cockpit wiring?
What is standard operating procedure for when and where to use ferrite sleeves?
Do both the positive and negative lead need to pass through the ferrite sleeve?
Thanks for the education.
It can all be a bit trial and error, but
http://audiosystemsgroup.com/SAC0305Ferrites.pdf
gives some of the theory and practical aspects of it.
Key points:
- mount "close" to interference source
(close = less than 1/20th of the wavelength)
- mount "close" to whatever is being affected by
the interference
- multiple loops are better, usually
- resonance can cause surprises; be prepared to experiment
- any piece of wire can be an antenna, including the
cable shields
Trying again: Collings Foundation B-17 at Newcastle Airport inDelaware - B-17 cockpit.jpg - B-17 cockpit.jpg (1/5) Jim Breckenridge Aviation Photos 1 August 30th 08 07:36 PM
Trying again: Collings Foundation B-17 at Newcastle Airport in Delaware - B-17 cockpit.jpg - B-17 cockpit.jpg (0/5) Go-dot Aviation Photos 0 August 28th 08 11:39 PM
Wings of Freedom B-17 Wilmington, DE - B-17 cockpit.jpg - B-17 cockpit.jpg (0/5) Go-dot Aviation Photos 0 August 28th 08 09:37 PM
Retraction (lowering?) assist springs on V2C [email protected] Soaring 1 January 5th 06 05:20 PM
Lowering Stall Dick Home Built 7 December 25th 03 03:19 PM
