Power Flarm Display
Old December 17th 12, 05:02 PM posted to rec.aviation.soaring
Default Power Flarm Display
On Wednesday, December 12, 2012 5:44:06 PM UTC-5, Richard wrote:
On Wednesday, December 12, 2012 10:28:43 AM UTC-8, bumper wrote:
On Wednesday, December 12, 2012 10:17:39 AM UTC-8, Morteza Ansari wrote: Not sure which butterfly display we are talking about, but the rectangular display that comes with the brick is anything but *useless* to anyone flying with polarized sun glasses. It is polarized incorrectly which means if you mount it in horizontal orientation you see practically nothing on the display. Yes, but it works just fine with my polarized glasses in the vertical mode. So I made a bracket to hold it at the edge of the glareshield to the left of center. Since the device and display are rotatable in increments of 90 degrees, and since all LCD displays I've seen are polarized in one plane or another, Butterfly had to pick one knowing full well that it would please some and offend others of the polarized sun glassed crowd. No way for them to win! bumper
The latest Firmware Version of the Butterfly display is out 3.01
It has:
New Features:
• Nondirectional traffic is shown permanently (PCAS)
• Supports PowerFLARM® CORE
• NEAREST-Mode, always automatically shows nearest target
• Units con"gurable
• Enhanced Menu
Improvements:
• Better stability with many received targets
• new dynamical menu for future extensions.
• 3.0.1: Better font readability
I just saw an ADS B target the fonts are much larger and readable.
You need a special cable to update the firmware.
Make the cable instructions and get firmware at
http://www.butterfly-avionics.com/in...upport-english
or send to your dealer or Craggy Aero.
Richard
www.craggyaero.com
All,
I looked at the update information, and although it specified what connector pins on the display connector (RJ-12) were to be connected to what pins on a PC serial connector, it didn't specify the connector itself or address the issue of how one determines whether or not the PC can supply 3.3vdc on pin 5. I emailed the Butterfly folks, and I have copied the reply here. You will note that the reply still doesn't directly address the 3.3vdc issue, but at this point I'm confident enough that its not going to be a problem that I plan to fabricate a RJ12-DB9 cable and give it a whirl.
Frank (TA)
------------------------------------- CUT HERE ---------------------------
Aktualisiert von: Frank Paynter, 14. Dez 15:40 (CET):
Hi,
I would like to update the firmware on my PowerFlarm Butterfly display, but
I'm a bit confused by the directions for fabricating the required update
cable. Note that I'm an Electrical Engineer with over 40 years of bench
design and fabrication experience, so if I'm confused, I expect others are
as well.
The instructions provide a pinout for the display-end connector, with notes
as to where each pin should go on the PC end. However, the PC-end
connector isn't specified - is it supposed to be a DB9 serial connector?
If so, you must know that DB9 serial connectors aren't widely available on
modern PC's; I have 6 PCs in my home office, and not one of them has a DB9
serial connector. When I need serial port connectivity, I use a popular
USB-serial adapter. Will your display update properly when using such an
adapter?
Your specification calls for pin 5 of the RJ-12 connector to be tied to
+3.3VDC, but this isn't a common voltage for serial communications. What
happens if this line is connected to +5 or even +12 VDC?
Regards,
Frank
Aktualisiert von: Marc Foerderer, 17. Dez 11:54 (CET):
Dear Frank,
thanks for your message.
Yes a normal RS232 to USB adapter works fine, the connector depends of course on your use-case. Most PCs or at least RS232 serial adapters have a DB9 connector.
3v3DC is the supply voltage for the device itself, the RS232 pins are 12V tolerant.
If you have more questions, please contact me
Best regards
Marc Förderer
Butterfly Avionics GmbH
Old December 17th 12, 07:06 PM posted to rec.aviation.soaring
bumper[_4_]
Frank (TA)
Hi,
as well.
adapter?
Regards,
Frank
Frank,
Please post an update if all goes well. I prefer not to tune my device for maximum smoke if there is some other brave soul willing to go first!
tks
bumper
Old December 17th 12, 07:43 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Frank (TA)
Hi,
as well.
adapter?
Regards,
Frank
Frank,
tks
bumper
You guys do know about this, yes? (From external display manual)
"Updates
Update through PowerFLARM®
After Q4/2012 it will be possible to update the displays through any PowerFLARM® unit
directly without the need for a special cable."
-Evan Ludeman / T8
Old December 18th 12, 02:56 PM posted to rec.aviation.soaring
Frank (TA)
Hi,
as well.
adapter?
Regards,
Frank
Frank,
tks
bumper
"Updates
-Evan Ludeman / T8
Evan,
Just saw this myself in the Butterfly manual - wonder why they didn't mention this in the response to my email?
Frank (TA)
Old December 18th 12, 10:17 PM posted to rec.aviation.soaring
Jim[_32_]
Frank (TA)
Hi,
as well.
adapter?
Regards,
Frank
Frank,
tks
bumper
"Updates
-Evan Ludeman / T8
Evan,
Frank (TA)
Hi Frank, I built my update cable several weeks ago (for the last update and to download flarmnet info) and it worked just fine with 2 AA batteries (just as someone else mentioned in this thread). RS232 adapters don't ever work well for me on laptops so the only reliable serial port I have is on my desktop. Since my rectangular display is screwed to my panel with the 4 provided screws I think I will wait until the post-Q4-instructions to magically appear just to save the hassle of un-mounting the display yet again.
Old December 19th 12, 02:45 PM posted to rec.aviation.soaring
All,
Here is the email I sent to Butterfly, and their response. Assuming the FLARM guys aren't too late with their next update, that sure sounds like the way to go [sound of partially made cable hitting trashcan]
Frank (TA)
-------------------------- CUT HERE -----------------------------------
Dear Frank,
+12VDC supply damage the display?
yep, definitely. The display can work with 3V to 3.6VDC, all above will damage the unit.
Core/Brick Updating: We are literally just working on this this week. It will be included in the next PowerFLARM release which will come soon in the new year (this depends on FLARM in Switzerland, the display-updating-routine is only a small part of the release)
Best wishes
Marc
Aktualisiert von: Frank Paynter, 18. Dez 16:08 (CET):
Marc,
A couple of questions:
Can I connect the 3.3vdc line to the DB9 +V line (typically +5 to +12VDC)
or do I need to supply 3.3VDC somehow? In other words, would a +5 or
There is a note in your current manual about the upcoming ability to update
a Butterfly display via an attached FLARM 'brick' (Core) device. Is this
ability available now? If not, can you give me an estimate of when it will
become available? Obviously, eliminating the need for a separate update
cable would be welcome indeed!
TIA,
Frank
Frank (TA)
Hi,
as well.
adapter?
Regards,
Frank
Frank,
tks
bumper
"Updates
-Evan Ludeman / T8
Evan,
Frank (TA)
Old March 16th 13, 07:09 PM posted to rec.aviation.soaring
John Carlyle
My Butterfly 57mm display is running firmware V.2.9.4. FLARM promised in December that the "next PowerFLARM release which will come soon in the new year" will upgrade displays without using the special Butterfly cable. The only PowerFLARM release I can find is V2.40 from July 24, 2012. This of course is older than the V2.71 that was used to get the PowerFLARM IGC flight recorder approval.
QUESTIONS
1) Does V2.71 have the display updating code?
2) Can one download V2.71 from somewhere? If so, what's the URL?
-John, Q3
"Updates
After Q4/2012 it will be possible to update the displays through any PowerFLARM® unit directly without the need for a special cable."
-Evan Ludeman / T8
Old March 17th 13, 05:53 AM posted to rec.aviation.soaring
Ramy
Yes. There is a beta version which works well, but I think it is not public. Not sure why.
Ramy
Old March 17th 13, 12:35 PM posted to rec.aviation.soaring
John Carlyle
Interesting and encouraging. Hopefully the beta will be released publicly soon.
When you say "works well", do you mean that it updates the display without special cables, as well as doing the FLARM anti-collision and logging work?
I did find version 2.60 from Oct 2012. For some reason (maybe the formatting on the PowerFLARM.us site) I missed seeing it yesterday.
-John, Q3
Ramy
Old March 18th 13, 01:03 AM posted to rec.aviation.soaring
Evan Ludeman[_4_]
-John, Q3
Ramy
2.60 adds (non igc approved) flight logging but not the display update pass through. I flew with 2.60 today. My only complaint about log file transfer is that it's blind since I use a USB extension and I can't see the little blinking light on my Core unit. Flarm guys **please** give us some way to monitor file xfer on the butterfly display.
Other comments... lots of adsb traffic visible on ClearNav today, most in the flight levels of course, but two contact down around 6k - 7k. Tens of miles range. Right now, CN displays these adsb targets as other *gliders*. I've put in a suggestion about that. Sadly, my mode c/s pcas range on powerflarm still stinks, it's one or two miles *at best*. Saw a bizjet rip by at less than 2 miles. Not a peep :-(.
-Evan Ludeman / T8
Power FLARM as logger Lucky812 Soaring 27 December 7th 12 02:13 PM
US Power FLARM Antennas Andy[_1_] Soaring 13 June 21st 12 07:34 AM
Power FLARM deliveries? Andy[_1_] Soaring 1 June 5th 12 01:33 PM
Portable Power Flarm for sale [email protected] Soaring 1 June 2nd 12 01:14 AM
Power FLARM question Kimmo Hytoenen Soaring 26 March 23rd 12 04:28 AM
