Power Flarm Display
Old December 18th 12, 02:56 PM posted to rec.aviation.soaring
Default Power Flarm Display
On Monday, December 17, 2012 2:43:38 PM UTC-5, Evan Ludeman wrote:
On Monday, December 17, 2012 2:06:01 PM UTC-5, bumper wrote:
On Monday, December 17, 2012 9:02:00 AM UTC-8, wrote:
I'm confident enough that its not going to be a problem that I plan to fabricate a RJ12-DB9 cable and give it a whirl.
Frank (TA)
------------------------------------- CUT HERE ---------------------------
Aktualisiert von: Frank Paynter, 14. Dez 15:40 (CET):
Hi,
I would like to update the firmware on my PowerFlarm Butterfly display, but
I'm a bit confused by the directions for fabricating the required update
cable. Note that I'm an Electrical Engineer with over 40 years of bench
design and fabrication experience, so if I'm confused, I expect others are
as well.
The instructions provide a pinout for the display-end connector, with notes
as to where each pin should go on the PC end. However, the PC-end
connector isn't specified - is it supposed to be a DB9 serial connector?
If so, you must know that DB9 serial connectors aren't widely available on
modern PC's; I have 6 PCs in my home office, and not one of them has a DB9
serial connector. When I need serial port connectivity, I use a popular
USB-serial adapter. Will your display update properly when using such an
adapter?
Your specification calls for pin 5 of the RJ-12 connector to be tied to
+3.3VDC, but this isn't a common voltage for serial communications. What
happens if this line is connected to +5 or even +12 VDC?
Regards,
Frank
Frank,
Please post an update if all goes well. I prefer not to tune my device for maximum smoke if there is some other brave soul willing to go first!
tks
bumper
You guys do know about this, yes? (From external display manual)
"Updates
Update through PowerFLARM®
After Q4/2012 it will be possible to update the displays through any PowerFLARM® unit
directly without the need for a special cable."
-Evan Ludeman / T8
Evan,
Just saw this myself in the Butterfly manual - wonder why they didn't mention this in the response to my email?
Frank (TA)
Old December 18th 12, 10:17 PM posted to rec.aviation.soaring
Jim[_32_]
Frank (TA)
Hi,
as well.
adapter?
Regards,
Frank
Frank,
tks
bumper
"Updates
-Evan Ludeman / T8
Evan,
Frank (TA)
Hi Frank, I built my update cable several weeks ago (for the last update and to download flarmnet info) and it worked just fine with 2 AA batteries (just as someone else mentioned in this thread). RS232 adapters don't ever work well for me on laptops so the only reliable serial port I have is on my desktop. Since my rectangular display is screwed to my panel with the 4 provided screws I think I will wait until the post-Q4-instructions to magically appear just to save the hassle of un-mounting the display yet again.
Old December 19th 12, 02:45 PM posted to rec.aviation.soaring
All,
Here is the email I sent to Butterfly, and their response. Assuming the FLARM guys aren't too late with their next update, that sure sounds like the way to go [sound of partially made cable hitting trashcan]
Frank (TA)
-------------------------- CUT HERE -----------------------------------
Dear Frank,
+12VDC supply damage the display?
yep, definitely. The display can work with 3V to 3.6VDC, all above will damage the unit.
Core/Brick Updating: We are literally just working on this this week. It will be included in the next PowerFLARM release which will come soon in the new year (this depends on FLARM in Switzerland, the display-updating-routine is only a small part of the release)
Best wishes
Marc
Aktualisiert von: Frank Paynter, 18. Dez 16:08 (CET):
Marc,
A couple of questions:
Can I connect the 3.3vdc line to the DB9 +V line (typically +5 to +12VDC)
or do I need to supply 3.3VDC somehow? In other words, would a +5 or
There is a note in your current manual about the upcoming ability to update
a Butterfly display via an attached FLARM 'brick' (Core) device. Is this
ability available now? If not, can you give me an estimate of when it will
become available? Obviously, eliminating the need for a separate update
cable would be welcome indeed!
TIA,
Frank
Frank (TA)
Hi,
as well.
adapter?
Regards,
Frank
Frank,
tks
bumper
"Updates
-Evan Ludeman / T8
Evan,
Frank (TA)
Power FLARM as logger Lucky812 Soaring 27 December 7th 12 02:13 PM
US Power FLARM Antennas Andy[_1_] Soaring 13 June 21st 12 07:34 AM
Power FLARM deliveries? Andy[_1_] Soaring 1 June 5th 12 01:33 PM
Portable Power Flarm for sale [email protected] Soaring 1 June 2nd 12 01:14 AM
Power FLARM question Kimmo Hytoenen Soaring 26 March 23rd 12 04:28 AM
