On 12/23/2012 9:20 AM, JohnDeRosa wrote:
We had an overhead bi-fold hangar door cable snap yesterday (one of five). Snip... The cable had rusted through inside the guide tube on the wind up spool. We had one hell of a time getting the old rusty cable out of that old rusty tube. We are wondering when the other cables will suffer the same fate. Everything else being equal, and painting with a broad brush here, the other cables are likely "in similar condition" as the one that has already failed, though under 25% higher load now. Maybe in summer you'd feel warmer and fuzzier. :-) Questions; - What type of cable (3/16") should be used? Aviation? Stainless? Galvanized? More "common sense engineering" follows... - Given the service life rendered by the existing cables, anything of similar material (you used the word "rust", so we're talking steel?) and cross section should be in the same life ballpark. I'm sure you're aware aluminum has lower tensile strength than steel for a given cross sectional area. Point being, you won't go too far wrong "replacing with like." Assuming the same cross sectional area, the number of strands affects only the minimum recommended bend radius of whatever corners the cable must go around. More strands, more bendy. - In your use, my take is corrosion is your long-term enemy (Duh!). IOW, if what's rusted rusted because it was a non-CRES steel (cheaper than CRES steel), then pocketbook reality will need to be balanced against cable-life realities (as in...it's rusted once, what are you going to change to preclude rusting in the future? Personally, when I have to do "major/PITB structural repairs" I like to do what I can to ensure the next repair need will occur after I croak.) - galvanized cable (if available) achieves its corrosion resistance from a surface coating, meaning that once the coating is violated, corrosion has a direct entry path. Presuming the interior metal is not CRES steel (else, why coat it?), I'd do a kentucky windage guess the life of galvanized cable would be closer to that of non-CRES bare steel cable, than of a CRES steel cable. - What kind of swedged stop sleeves should be used? Aluminum? Copper? Steel? You won't go far wrong using a swage of similar (as possible) materials, both for strength-matching and galvanic reasons. I'd reckon strength information is readily available on the web for the number crunchers in your Club. In the absence of number crunching, certainly don't go smaller than what's already there, dry chuckle... - How to prevent rusting inside the tube? We greased the cable end in hopes that this will help. Short of obtaining a tube of CRES material, regular usage will be your best preventer of tube corrosion (if I'm understanding the question correctly). Activation abrasion, if you will... Thanks, John Rotsa ruck!!! Bob W. |
hangar door information | aa5flyer | Owning | 0 | November 12th 05 01:05 PM |
T-hangar's bi-fold door: Convert to a motorized opening door? | Peter R. | Piloting | 16 | August 21st 04 01:06 AM |
wanted: hangar door tips | Joa | Home Built | 35 | April 18th 04 02:19 PM |
wanted: hangar door tips | Joa | Owning | 36 | April 18th 04 02:19 PM |
wanted: hangar door tips | Joa | Piloting | 35 | April 18th 04 02:19 PM |
