Oudie 2 Lite - how to Autorun XCSoar (or something other than SeeYou Mobile)
Old December 27th 12, 03:56 PM posted to rec.aviation.soaring
Default Oudie 2 Lite - how to Autorun XCSoar (or something other thanSeeYou Mobile)
Thanks,
I have the Oudie 2 Lite I got for Christmas waiting for me at home. I can't wait to try it out with XC-Soar.
Old January 7th 13, 11:39 PM posted to rec.aviation.soaring
JohnDeRosa
I am interested is doing this but my Autorun page only have one
choice; "Automatically run SeeYou Mobile". There is no "...". I am
running the latest firmware, 4.34.002. Any ideas? Does the micro-SD
card need to be formatted differently?
Old January 8th 13, 01:31 AM posted to rec.aviation.soaring
JohnDeRosa
On Jan 7, 5:39*pm, JohnDeRosa wrote:
I am running the latest firmware, 4.34.002.
I had to update to 4.34.003. Now I have the "..." feature in
Autorun. Unfortunately, the Naviter change log for 4.34.xxx is
EMPTY! http://www.naviter.com/products/seey...ile-change-log
Also, an interesting thread in the XCSoar forum points to what seems
to be an easier way to change back and forth from SYM to XCSoar rather
than going through the Autorun menu. I assume this would work with
any Windows Mobile executable. http://forum.xcsoar.org/viewtopic.php?f=4&t=343
- John
Old January 8th 13, 02:31 AM posted to rec.aviation.soaring
David Laitinen
I wrote one of the recent entries on that forum. I find the new
3.34.003 the easiest way to switch. I wrote my append based on 4.34.002
and that required connecting to another PC to rename program files to
switch back and forth. It's much easier now to go to the autorun
setting and selecting the program to run.
David Laitinen
- John
Old January 8th 13, 03:46 AM posted to rec.aviation.soaring
JohnDeRosa
David Laitinen
I tried both ways and I think that the way shown at
http://forum.xcsoar.org/viewtopic.php?f=4&t=343 is easier/simpler/
faster. However, it may only work with an Oudie 1.
In the Oudie 1 there are three program icons on the home screen,
SeeYou Mobile, ConnectMe and PocketFMS. PocketFMS is not loaded on
the Oudie 1 so it is basically a useless icon. In the easier scheme I
linked above, this icon is re-used to run XCSoar. Thus you can run
either SYM or XCSoar from the same screen with just a single tap. This
will be useful when changing software in mid-flight.
Unfortunately, the Oudie 2 that I tested only had SeeYou Mobile and
ConnectMe icons on the home screen. If true with all Oudie 2's you
will need to use the AutoRun method to switch between programs.
- John
New lower price for SeeYou Products - Oudie at $578 Paul Remde Soaring 2 July 1st 10 08:58 PM
SeeYou Mobile 3.0 now available [email protected] Soaring 0 February 4th 08 12:17 PM
Using mobile SeeYou Robert Hart Soaring 3 May 10th 06 09:42 PM
SeeYou MOBILE v2.0! Roy McMaster Soaring 10 July 12th 04 12:25 AM
SeeYou Mobile Robert Fidler Soaring 0 March 17th 04 04:18 PM
