Best HD Video Camera for Flight Videos
Old January 1st 13, 06:36 PM posted to rec.aviation.soaring
cfinn[_2_]
Default Best HD Video Camera for Flight Videos
The brand name is Aquaplast. Here's a link you could use:
http://www.wisdomking.com/aquaplast-splinting. You can get it in 18x24
sheets 1/16 or 1/8 inch thick.
Charlie
On Dec 31 2012, 10:27*pm, Eric Greenwell
On 12/31/2012 5:26 PM, wrote:
Next Season I will be adding a wing mounted camera, using a suction
cup and a wing cuff made out of a medical plastic called "aqua
plastic."
Where do you get this? My search found some strange results that won't
be useful for wing mounted cameras.
email me)
Old January 1st 13, 10:06 PM posted to rec.aviation.soaring
I will be ordering from them tomorrow, little hung over today..
I might take a video of the process and post it if I am successful.
Happy New Year to all
plastic."
email me)
Old January 1st 13, 10:51 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
I've done a little research and have discovered that the generic term for
all these products is 'splinting materials', which are roughly split into
two types of material:
1) "casting tape". This is a knitted synthetic fiberglass fabric
impregnated with a water-activated polyurethane resin. This is dipped in
room temperature water for about 10 secs, squeezed to remove the excess
water and smoothed into position using gloves. It sets in 3-5 mins and,
in the case of a splint is hard enough to be load-bearing in 20 mins.
The tape is 50-100mm wide and seems to come in 2m lengths. Load bearing
structures are typically 3-6 layers thick and load-bearing splints are
recommended to be 4 layers.
2) sheets of solid or perforated thermosetting plastic which are cut to
shape, heated to soften and then moulded around whatever they are meant
to fit. This material is quite a bit more expensive than casting tape.
Confusingly, 'Aquaplast' seems to be the thermoset material rather than
casting tape. Some brand names for casting tape a
- 3M Scotchcast Plus Casting Tapes
- Alto Cast
- Ossur Techform
These are available from medical supply houses and on eBay.
OTOH, you may find its cheaper to pick up some glasscloth, epoxy resin
and a decent release film from your local model store and use these to
make the wing glove from these: you'll need the release film in either
case.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old January 2nd 13, 03:41 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
- Alto Cast
- Ossur Techform
case.
The Aquaplast looks great, but I'll stick with the cloth and epoxy, I think.
email me)nyurl.com/yfs7tnz
Old January 2nd 13, 08:43 PM posted to rec.aviation.soaring
for all these products is 'splinting materials', which are roughly
split into two types of material:
in room temperature water for about 10 secs, squeezed to remove the
excess water and smoothed into position using gloves. It sets in 3-5
mins and, in the case of a splint is hard enough to be load-bearing in
20 mins. The tape is 50-100mm wide and seems to come in 2m lengths.
Load bearing structures are typically 3-6 layers thick and load-bearing
splints are recommended to be 4 layers.
- 3M Scotchcast Plus Casting Tapes - Alto Cast - Ossur Techform
case.
think.
That would be my choice too. Three reasons:
(1) I know how to work with glass/epoxy
(2) making a fairly wide glove, 250mm - 300mm, seems like a good idea
(3) the need for a good bond between the glove and the camera mount
(2) and (3) are probably be easier with glass cloth than with either type
of splint material.
org |
Another small, cheap video camera, with audio! RL Soaring 1 December 28th 10 04:19 PM
Another video using the cheap '808 Keychain camera' Grider Pirate Soaring 12 November 19th 10 02:37 AM
Very Nice Camera for Glider...Stills or HD Video [email protected] Soaring 17 June 16th 09 10:28 PM
gratis jamba handyvideo lustige jamba videos fuer handy jamba videoin handy format jamba handy video 3gp jamba handy videos free download jambahandy video schuelerin [email protected] Piloting 0 May 25th 08 01:00 PM
Apache gun camera video Andrew Military Aviation 34 January 17th 04 02:48 PM
