The new Electric Cessna 172
Old January 1st 13, 03:40 PM posted to rec.aviation.piloting
Default The new Electric Cessna 172
On Tuesday, January 1, 2013 10:10:37 AM UTC-5, a wrote:
There was a contest recently where one had to demonstrate more than 200 passenger miles per gallon equivalent, and an engineering team from Penn State won it with a battery powered airplane.
See
http://live.psu.edu/story/55543
for details.
http://nextbigfuture.com/2009/12/sup...-electric.html
Mark
Old January 1st 13, 06:24 PM posted to rec.aviation.piloting
Mark
Practical, manufacturable high temperature superconductors would enable
a whole bunch of neat things and would be as spectacular as a cure for the
common cold, lasting peace in the Middle East, and controlled fusion, and
is just as likely to happen in the near future.
Old February 1st 13, 02:54 PM posted to rec.aviation.piloting
On Jan 1, 1:24*pm, wrote:
http://nextbigfuture.com/2009/12/sup...enable-electri...
Mark
I recently read up on some work being done with graphene
supercapacitors. I IRC, it was at Caltech. What was interesting is how
they performed at lower temperatures (e.g. room temp.). Also, charging
times were impressive. Still in the realm of research, so it wasn't
clear to me how well it would scale beyond smaller applications
(consumer electronics, for example.
Old February 1st 13, 05:25 PM posted to rec.aviation.piloting
Mark
Supercapacitors are great for things like keeping your clock from flashing
on every minor power failure, but not that great for real power application.
The basic physics of capacitors says the energy density can never be as
good as existing batteries. Graphene makes them better but it will take
yet to be invented materials to match batteries.
Capacitors are also a poor choice for running something like a motor because
of their discharge curve.
While a battery's discharge curve is basically flat until it gets close to
full discharge, then takes a big dive, a capacitor discharge curve is a
straight line between fully charged and zero.
Motors operate over a narrow voltage range. Electric motor speed control
is done by pulsing the motor voltage on and off, not by varying a constant
voltage.
Now it is possible to build a thing that will take in a lower voltage and
output some constant higher voltage to keep a motor happy.
The problem with that is it is more complexity subject to failure, not
good with airplanes, and it would require big, heavy, high current
transformers, which ups the weight a good bit.
My wild assed guess is that if electric airplanes ever become practical
without Star Trek technology, it will likely be through a fuel cell that
is yet to be invented.
Old February 1st 13, 06:16 PM posted to rec.aviation.piloting
http://nextbigfuture.com/2009/12/sup...enable-electri....
Mark
voltage.
Most of what I was reading didn't seem to indicate that the goal is to
replace, but rather to compliment existing technologies, e.g. charging
applications.
http://phys.org/news/2012-10-sponge-...ectrodes..html
- Graphene
http://phys.org/news/2011-08-energy-...-electric.html
- SMC
I'm not saying it will (ever) power an airplane. Just looked
interesting and sometimes there are great discoveries that come out of
research, often in applications that were never part of the planned
research itself.
Peace.
Old February 1st 13, 07:01 PM posted to rec.aviation.piloting
snip old stuff
applications.
http://phys.org/news/2012-10-sponge-...lectrodes.html
- Graphene
- SMC
Lot's of little techical problems in both of those articles.
The biggest is talking about recharging in minutes.
It is a rather simple calculation to calculate the current requirments
to recharge a device (doesn't matter battery or capacitor) to the full
energy level in a few minutes.
When you do that you discover that the size of the cable required so that
it will not vaporize due to the current density is as big around as your
leg with matching connectors.
Energy sources are rated in KWh and is equivalent to 1000 x V x A x h.
A typical electric car battery is around 30 KWh and 100 volts and 6 minutes
is 0.1 hours so:
30,000 / (100 x .1) = 3,000 Amps
To put the wire required in perspective, those big heavy cables on an
arc welder are good for a current of around 100 Amps so your charging
cable would have to be about 30 times bigger than arc welder cables.
research itself.
Yeah, that is usually the case.
Peace.
Electric jets where are You? nrepeb General Aviation 5 March 13th 11 08:56 PM
FS: Electric tow Bug Dout General Aviation 0 October 16th 10 06:27 PM
6CH Electric RC Helicopter for $169 GTY Rotorcraft 0 October 27th 05 08:59 PM
Electric RC Helicopter for $83 NYPT Man Home Built 0 October 24th 05 06:47 PM
Electric DG Robbie S. Owning 0 March 19th 05 03:20 AM
