On Jan 7, 8:31*pm, David Laitinen wrote:
It's much easier now to go to the autorun setting and selecting the program to run. David Laitinen I tried both ways and I think that the way shown at http://forum.xcsoar.org/viewtopic.php?f=4&t=343 is easier/simpler/ faster. However, it may only work with an Oudie 1. In the Oudie 1 there are three program icons on the home screen, SeeYou Mobile, ConnectMe and PocketFMS. PocketFMS is not loaded on the Oudie 1 so it is basically a useless icon. In the easier scheme I linked above, this icon is re-used to run XCSoar. Thus you can run either SYM or XCSoar from the same screen with just a single tap. This will be useful when changing software in mid-flight. Unfortunately, the Oudie 2 that I tested only had SeeYou Mobile and ConnectMe icons on the home screen. If true with all Oudie 2's you will need to use the AutoRun method to switch between programs. - John |
New lower price for SeeYou Products - Oudie at $578 | Paul Remde | Soaring | 2 | July 1st 10 08:58 PM |
SeeYou Mobile 3.0 now available | [email protected] | Soaring | 0 | February 4th 08 12:17 PM |
Using mobile SeeYou | Robert Hart | Soaring | 3 | May 10th 06 09:42 PM |
SeeYou MOBILE v2.0! | Roy McMaster | Soaring | 10 | July 12th 04 12:25 AM |
SeeYou Mobile | Robert Fidler | Soaring | 0 | March 17th 04 04:18 PM |
