Help with location of transponder antenna
Old January 8th 13, 11:43 PM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
Quote:
Originally Posted by View Post
Glider is a Discus 2cT (carbon fuse). Antenna is an external aerodynamic blade style.
Although at some point SH mentioned mounting an antenna on top of the fuse BEHIND the engine bay I have been unable to obtain any drawings or specifications on how to reach this location and it looks like a major PIA to do so..
Assuming there are no details on the rear location mount, my preferred choices would be:
Location 1): On top of the fuse approximately 12" behind the canopy mounted directly in the center. This would be a simple and aesthetically pleasing install but I have not been able to find any data to prove or disprove any health risks by mounting the antenna this close to my (IMO) good looking cranium.
Given the requirement to mount the antenna externally due to the carbon fuse blocking an interior signal from getting OUT, I'm left wondering if the same carbon fuse should then protect me from an external antenna signal coming back IN? (I also heard a rumor that Knoff mounted an antenna in this location on a Duo Discus?)
Location 2: Next to the gear pointing out (down) at roughly 45 degrees. This is again an easy install, astheticaly a little less pleasing being offset at an angle, and once again brings up the question of proximity to my brain.
Thanks so much for any input.
Scott
Hi Scott
You can find some info here, http://www.schempp-hirth.com/fileadm...63-17-2424.pdf
I am given to understand that there is a cost associated with this tech note i.e. pay for drawings etc, but an email to the factory or alternatively the US agents would clear this up
This link is for mounting under the fuse at an angle http://www.schempp-hirth.com/fileadm...3-4-D-2202.pdf
Cheers
Colin
Transponder antenna location and type. [email protected] Soaring 1 September 14th 09 03:18 PM
Transponder Antenna Location [email protected] Soaring 15 January 17th 08 06:56 PM
GPS Antenna Location Kevin Neave Soaring 6 November 25th 06 12:50 AM
LS-4 Transponder antenna location? Matt Herron Soaring 3 February 25th 04 03:45 PM
Transponder Antenna Location Ken Kochanski Soaring 9 January 9th 04 10:16 PM
