On Tue, 22 Jan 2013 17:40:11 -0800, kirk.stant wrote:
90 degree bank is a lot steeper than most pilots imagine. Unless you are current in acro anything over 60 degrees will feel like 90. And unless its a transient condition caused by turbulence any intentional 90 degree bank for more than a few seconds would result in an impressive sink rate regardless of the strength of the thermal. But it makes for a good hangar story: "There I was at 300 ft over the nuke cooling tower, banked to 90 degrees and barely climbing..." It stands to reason that you can't climb in a 90 degree bank because there's no vertical lift vector unless, of course, you so much top rudder fed in that you're climbing on lift generated by the fin and fuselage sides. However, a couple of times I've certainly been using around 70 degrees bank and still going up like the clappers: - once on a Pegase 90 when I was climbing in the chimney plume from the Stewartby Brick works just west of Bedford. That was odd: there was nothing (not even sink) outside the plume and in it you could center nicely by maximising the smell of furnace oil fumes. It was very narrow: I had the stick almost fully back to turn tightly enough and needed to extreme bank to turn that tight, bit I got 6-7 kts out of it - a similarly tight thermal with no apparent reason for it being too tight, over our airfield. This time solo in the club's Puchacz and again cranked over at least at least 70 degrees and with the stick well back to turn as tight as possible. Any wider turn left me out in the surrounding turbulence and sink. Again I got a strong climb to cloud base directly under a nice street. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Wednesday, January 23, 2013 4:35:45 PM UTC-7, Martin Gregorie wrote:
It stands to reason that you can't climb in a 90 degree bank because there's no vertical lift vector unless, of course, you so much top rudder fed in that you're climbing on lift generated by the fin and fuselage sides. However, a couple of times I've certainly been using around 70 degrees bank and still going up like the clappers: Precisely. 70 degrees is about 3 Gs, would give you a turn diameter of a little less than 200 ft (!) at 55 knots. But I doubt many pilots actually practice constant 70 degree banked turns, it's not as easy as it looks. Hard enough to get a lot of pilots to bank over 30 degrees - grrrr! It sure is fun to rack it up when you find the right thermal - the harder you pull, the faster you go up! Do it with someone you know across the thermal and it gets really interesting... Kirk 66 |
kirk.stant wrote:
Precisely. 70 degrees is about 3 Gs, would give you a turn diameter of a little less than 200 ft (!) at 55 knots. But I doubt many pilots actually practice constant 70 degree banked turns, it's not as easy as it looks. Hard enough to get a lot of pilots to bank over 30 degrees - grrrr! It sure is fun to rack it up when you find the right thermal - the harder you pull, the faster you go up! Do it with someone you know across the thermal and it gets really interesting... When I was pre-solo, on a very unprepossessing March day in the UK (solid stratus at 3400ft), my very experienced instructor "found"[1] something. Given the conditions, it can't have been a thermal. We were flying at 70kt in a K13 and noticing the G force, but we were rising at =10kt until we abandoned the climb at cloudbase. There was a glider opposite us sharing the thermal, so we kept an eye on each other's position by looking at the top of our heads. Glorious, and a good anecdote for indicating why flying in gliders is almost entirely unlike flying in spamcans. [1] I hesitate to say "blundered into" ![]() |
"kirk.stant" wrote: Precisely. 70 degrees is about 3 Gs, would give you a turn diameter of a little less than 200 ft (!) at 55 knots. But I doubt many pilots actually practice constant 70 degree banked turns, it's not as easy as it looks. Hard enough to get a lot of pilots to bank over 30 degrees - grrrr! It sure is fun to rack it up when you find the right thermal - the harder you pull, the faster you go up! Do it with someone you know across the thermal and it gets really interesting... Kirk 66 Have had pretty much that experience a few times. Banked very steeply, pulling hard, watching the guy across the thermal nearly through the top of my canopy. After a bit, it seems like the gliders are stationary and the world becomes a blurred, whirling cylinder. --- news://freenews.netfront.net/ - complaints: --- |
On Thursday, January 24, 2013 11:18:26 AM UTC-8, WB wrote:
In article , "kirk.stant" wrote: Precisely. 70 degrees is about 3 Gs, would give you a turn diameter of a little less than 200 ft (!) at 55 knots. But I doubt many pilots actually practice constant 70 degree banked turns, it's not as easy as it looks. Hard enough to get a lot of pilots to bank over 30 degrees - grrrr! It sure is fun to rack it up when you find the right thermal - the harder you pull, the faster you go up! Do it with someone you know across the thermal and it gets really interesting... Kirk 66 Have had pretty much that experience a few times. Banked very steeply, pulling hard, watching the guy across the thermal nearly through the top of my canopy. After a bit, it seems like the gliders are stationary and the world becomes a blurred, whirling cylinder. --- news://freenews.netfront.net/ - complaints: --- Since this thread drifted into discussion about bank angels, I'll add my 2 cents - next time you feel you are banking steeply, look at the screws in your panel and compare to the horizon. It will tell you if you are banking more or less than 45 degrees. Ramy |
USS Liberty Survivor Phil Tourney responds to Cindy McCain | NOMOREWARS_FORISRAEL | Naval Aviation | 0 | September 24th 11 11:22 AM |
A Fine Day at BFI - part 2 - Bell 407 N407KS King County Sheriff BFI 6-20-09 29.jpg | Bob (not my real pseudonym) | Aviation Photos | 0 | June 28th 09 09:32 AM |
A Fine Day at BFI - part 2 - Bell 407 N407KS King County Sheriff BFI 6-20-09 23.jpg | Bob (not my real pseudonym) | Aviation Photos | 0 | June 28th 09 09:32 AM |
AS responds to the latest Ventus 2cxa | KevinFinke | Soaring | 3 | March 18th 09 03:45 AM |
County Sheriff Arrests Pilot After Botched Landing | Larry Dighera | Piloting | 16 | May 16th 08 09:58 PM |
