#111
On Friday, February 8, 2013 3:35:32 PM UTC-5, rk wrote:
SR is only variometer that can show what is happening when you blaze trough thermal at 200kph. I have nothing to dispute. I just want to learn something. I see that the ability to get an accurate reading at high horizontal velocity is a feature that distinguishes the best varios from the lesser varios. At what speed do lesser varios start to degrade? Is the degradation abrupt or gradual? Specific examples would be helpful. Is there any other criteria where one modern vario is clearly better than another? |
#112
On Fri, 08 Feb 2013 13:51:52 -0800, son_of_flubber wrote:
On Friday, February 8, 2013 3:35:32 PM UTC-5, rk wrote: SR is only variometer that can show what is happening when you blaze trough thermal at 200kph. I have nothing to dispute. I just want to learn something. I see that the ability to get an accurate reading at high horizontal velocity is a feature that distinguishes the best varios from the lesser varios. At what speed do lesser varios start to degrade? Is the degradation abrupt or gradual? Specific examples would be helpful. Is there any other criteria where one modern vario is clearly better than another? Pass: confession time. I use relatively old varios and am happy with them. I have an SDI C4 (running V4.06 firmware), a Borgelt B.40 and LK8000. The C4 really needs a connection to a GPS that knows at least the next TP or it loses its final glide and wind calculation abilities. Unfortunately mine doesn't have a GPS connection at present, but I really like the noises it makes when climbing and running between thermals and its configuration is a good match on my glider's polar. Medium term plan is to add a GPS feed (its wind and final glide calculations are good) but in the interim LK8000 is handling these details well. I used to use a Garmin GPS II+ which, when it had a waypoint selected, sent the C4 what it needed to know to do a really good job on FG and wind. Now I run LK8000 for airspace awareness but the PNA it runs on has no connectivity for outputting the NMEA sentences the C4 needs so I'm looking at LK8000 for FG and wind. The C4 has a monochrome LCD display that's always easy to read and has enough area and configuration options to show all the info you need when you need it with little or no need to manually change the display. The B.40 is the fastest vario I've flown with and I love it! Its my preferred instrument for locating a thermal but, once established I use the C4 noises to keep centered. The B.40 is really my backup vario because it has a 9v battery strapped to its back and so is a good get-me- home device if/when the 12v batteries fail. Readability is not an issue since it has a conventional needle and dial. Other devices I like: - the Tasman V1000. Several of our club gliders have this fitted. It works well, makes nice noises and seems to be both fast and accurate. It has a monochrome LCD display using blocks that move round the edge to show instant climb rate and a digital average climb rate displayed in the centre. - the LX16 as a basic instrument. Has a fast, shockproof monochrome display and makes very fast responding and informative noises. Some of out club gliders have them fitted. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#113
On Fri, 08 Feb 2013 08:53:54 -0800, waremark wrote:
How important is the setup? The electronic varios all offer numerous configuration options. How about sharing thoughts on how best to set them up? For example who uses smart filtering on an LX vario, what setting and why? (Except of course that smart filtering does different things on different versions of LX). The best vario for you may be the one you know best with the setup you know best. Agreed. As I said above, I use an SDI C4. It allows you to set both the info you need to see in each stage of the flight (cruise, climb, after leaving the thermal) and how it should switch between cruise and climb mode (choice of manual, speed and GPS-detected thermal turn). I use speed. It has different speeds for cruise-climb and climb-cruise and, after tuning it to my glider and flying style, I find its usually in the mode I want, i.e. I don't need to touch it or change airspeed to put it in the mode I want. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#114
On 08/02/2013 22:35, rk wrote:
So far the best electrical variometer has been good old Zander SR940 (yes better than ZS1), which I've used in 3 different gliders for over 500 hrs. Every other system is a league below SR, including all the new LX varios (both facctories), which is worrying since I believe they have majority of new computer market these days. What makes the SR 940 the best? SR is only variometer that can show what is happening when you blaze trough thermal at 200kph. Others are usually all around place. My answer to this question is Zander SR800. I have about 800 hours in two gliders with that vario. My motivation is the same as yours. When the pointer read 2.5m/s flying through a thermal, you could stop, centre and expect to achieve 2.5m/s on the averager. (Zander's meters were bigger than than those used by other instrument makers. When I had 2.5m/s on the averager, the Cambridge pilots reported 3m/s, climbing at the same speed in the same thermal). I am not sure if this had anything to do with the electronics but more to do with the plumbing. The SR800 uses a capacity flask not direct pressure readings. I think all of the modern devices use direct pressure measurement and need fancy digital filtering to get the same needle movement as a capacity system. My last SR800 has long since died. I now have a B500 and XCSoar etc. The B500 is a touch disappointing compared to the SR800, but once again I think the plumbing is to blame as it is a pressure device sharing the compensation probe with a Winter mechanical (flask) device. Now I listen to the B500, I look at the winter mechanical if I want to see a needle and I use the bug trail on XCSoar for thermal centering intelligence and wind speed/direction into. But I think I get the best thermalling performance by looking out of the window and flying the glider. The airframe communicates as well at the electronics and audio provides reassurance. It is the most fun too! Ian |
#115
perjantai, 8. helmikuuta 2013 23.51.52 UTC+2 son_of_flubber kirjoitti:
Is there any other criteria where one modern vario is clearly better than another? Yes, I think there is several actually. - accuracy of variometer reading. When you turn in steady thermal and your vario average is same as whole thermal average from other source, you know that systematic error is pretty much zero. Many variometers are very optimistic. - accuracy and sensitivity in high total energy situations. Going through 2m/s thermal at 200kph and variometer says "2 m/s" (relative netto) is surprisingly hard thing to achieve. I think this is the part where modern acceleration/gyro sensors could improve things. - fast response speed combined with good gust filtering. If you thermal 1 m/s and suddenly hit 3 m/s, your variometer should give fast reading of 1 - 3m/s. Usually it is too slow reaction, or it is very fast reading of 1 - 5 - 4 - 3 m/s. Other problematic spot is hitting a bad spot while thermalling. Variometers tend to be better at telling you climb rate is improving than vice versa. This is true for mechanical variometers also, so there might be a mechanical reason for it. Often your feeling is that you are out of the core, but variometers are still showing good climb rate. - very good centering aid. This works really well in SR940&ZS1, and is fully configurable. Great thing to have if you are scraping in that last bubble after 7 hrs fligth. Once you get used to it, you wouldn't live without it. |
#116
My thoughts on the Tasman V1000. Three years ago I was new to soaring and updating an original condition Cirrus. I purchased the Tasman because it was modern and in my price range. I like the vario and the sounds it makes. I like the battery voltage feature. I like the averager. What I don't like is the rate of climb depiction via LCD segments. I find the needle on my mechanical Winter is easier to see at a glance. I can honestly say I have not used the Tasman "instantaneous rate" depiction since I installed it. It goes back to the analog versus digital argument among car manufacturers.. The digital dashboard didn't last very long.
For this reason and a few others I am awaiting my new LXNav V7. The Borgelt B40's in two of our club gliders seem to be excellent varios despite their age. I do like varios that have a dead band in the center. Those long final glides sure are nice in a quite cockpit. Lane |
#117
On Saturday, February 9, 2013 6:40:35 AM UTC-6, wrote:
My thoughts on the Tasman V1000. Three years ago I was new to soaring and updating an original condition Cirrus. I purchased the Tasman because it was modern and in my price range. I like the vario and the sounds it makes. I like the battery voltage feature. I like the averager. What I don't like is the rate of climb depiction via LCD segments. I find the needle on my mechanical Winter is easier to see at a glance. I can honestly say I have not used the Tasman "instantaneous rate" depiction since I installed it. It goes back to the analog versus digital argument among car manufacturers. The digital dashboard didn't last very long. For this reason and a few others I am awaiting my new LXNav V7. The Borgelt B40's in two of our club gliders seem to be excellent varios despite their age. I do like varios that have a dead band in the center. Those long final glides sure are nice in a quite cockpit. Lane Lane I put an LX16 in the Cherokee a few years ago and have found that i don't really look at it that much either, probably for the same reason and that my trusty old Winter is top center on the panel. I do like the audio though and the average display. In general my favorite vario at any given time is whatever one is showing up. the more up the better ![]() This year i started flying with a few B40's and like them. pete maybe we need to install a whistle or reed or something in the line from the flask to the pellet vario ![]() |
#118
So far I have enjoyed the best results with a Zander ZS1 and Peschges VP4. I would not recommend LX5000 and LX7000 from my experience. LX8000 is better than its predecessors but earns its merits more from the fancy stuff than the vario.
The quality of the vario depends mainly on the quality of your TE probe, static port and tubing. Most people like and get the best results from a vario they are used to. On this basis its hard to find a best performing vario. |
#119
On Sunday, February 10, 2013 12:45:37 AM UTC+2, Alexander Swagemakers wrote:
So far I have enjoyed the best results with a Zander ZS1 and Peschges VP4.. I would not recommend LX5000 and LX7000 from my experience. LX8000 is better than its predecessors but earns its merits more from the fancy stuff than the vario. The quality of the vario depends mainly on the quality of your TE probe, static port and tubing. Most people like and get the best results from a vario they are used to. On this basis its hard to find a best performing vario. That's true, especially for older gliders with sometimes shabby TE compensation systems. Modern generation, say gliders less than 20 years old, have quite good static systems that deliver consistent performance. I flew Zander SR in LS8, Discus-2, Ventus-2 and DuoDiscus, all of them with excellent results. VP4 in LS8 was ok but nothing special, IMHO. |
#120
The advice given by a UK former multiple world champion was to have a
simple vario with well sorted TE. Then to spend the balance on Aerotows. Speed to fly is simple, for an unballasted Discus either fly at 80kts or 55kts. PF At 15:49 10 February 2013, rk wrote: On Sunday, February 10, 2013 12:45:37 AM UTC+2, Alexander Swagemakers wrote= : So far I have enjoyed the best results with a Zander ZS1 and Peschges VP4= .. I would not recommend LX5000 and LX7000 from my experience. LX8000 is bet= ter than its predecessors but earns its merits more from the fancy stuff th= an the vario. =20 =20 =20 The quality of the vario depends mainly on the quality of your TE probe, = static port and tubing. Most people like and get the best results from a va= rio they are used to. On this basis its hard to find a best performing vari= o. That's true, especially for older gliders with sometimes shabby TE compensa= tion systems. Modern generation, say gliders less than 20 years old, have q= uite good static systems that deliver consistent performance. I flew Zander= SR in LS8, Discus-2, Ventus-2 and DuoDiscus, all of them with excellent re= sults. VP4 in LS8 was ok but nothing special, IMHO. |
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario | ufmechanic | Soaring | 0 | March 24th 09 05:31 PM |
Martin Mars, Performing Live In Downtown Vancouver! | Zomby Woof | Aviation Photos | 3 | January 20th 08 03:10 PM |
Martin Mars, Performing Live In Downtown Vancouver! | Zomby Woof | Naval Aviation | 2 | January 11th 08 06:10 PM |
Navy Performing Well, Keeps Eye on Future Force | Otis Willie | Naval Aviation | 0 | February 14th 05 10:06 PM |
AN-2 performing a loop | Maro_SK | Aerobatics | 1 | March 25th 04 08:18 PM |
