Progress on updating training gliders and new winch operations?
Old February 14th 13, 08:33 AM posted to rec.aviation.soaring
kirk.stant
Default Progress on updating training gliders and new winch operations?
On Wednesday, February 13, 2013 2:45:19 PM UTC+1, Vaughn wrote:
Indeed, every little bit helps. BUT! PCAS is no substitute for a
transponder, which makes you visible to the big & fast traffic out there.
I somewhat disagree. A transponder does absolutely NOTHING to protect you from VFR traffic that isn't talking to ATC. However, a PCAS does give you warning of all transponder-equipped traffic, including airliners and military.
So it depends a lot on where you fly and what kind of traffic you are worried about. Out West, where you are usually in O2 levels (Reno area comes to mind) a transponder makes a lot of sense, since VFR traffic is usually lower. In the midwest, away from Class B or C airspace, it doesn't really help much, while a PCAS is really useful, because there is a lot of VFR traffic at the lower altitudes that you usually fly in.
Best solution is obviously a PowerFLARM and a Mode S transponder.
My preference if a choice has to be made is warning of the presence of other traffic over hoping that they see and respond to your transponder.
Cheers,
Kirk
66
Ground launch payout winch systems...Are they suitable for gliders? [email protected] Soaring 13 August 13th 14 04:30 PM
Winch operations in MN? [email protected] Soaring 6 June 27th 08 01:14 AM
Winch operations Edward Winchester Soaring 7 April 13th 06 11:24 AM
Winch Launch Stresses on Vintage Gliders Mike Schumann Soaring 31 January 30th 06 09:29 PM
Winch Operations Frank Smith Soaring 19 February 14th 04 11:28 AM
