Turn coordinator? How dare they!
Old February 26th 13, 02:55 PM posted to rec.aviation.soaring
son_of_flubber
Default Turn coordinator? How dare they!
On Tuesday, February 26, 2013 1:11:34 AM UTC-5, Alan wrote:
I would agree and disagree with Dan about this. Obvious reasons
include expense (gyros are expensive), weight, and power.
Here is a relatively inexpensive, low-maintenance, non-gyro based, and low power consuming Turn and Bank Indicator (that claims to be much easier to use than the old style).
http://www.trutrakflightsystems.com/..._and_Bank.html
Old February 26th 13, 04:14 PM posted to rec.aviation.soaring
Bill D
I haven't used the Tru-Track but I have a lot of "hood time" with old fashioned partial-panel "needle-ball-airspeed-clock-compass" flying including unusual attitude recovery. Using a T&B and ASI to maintain aircraft control is a difficult skill to acquire and just as difficult to maintain. That said, given that a pilot is highly trained and very current, it does work.
However, there is a difference between airplanes and gliders WRT the T&B. An airplane T&B displays a "standard rate turn" (2 minutes per 360 turn) as two needle widths. (Needle on the "doghouse" for the old guys.) That's 6 times too sensitive for a glider where the typical turn rate is 20 seconds per turn. Turns to a heading are much easier with an airplanes slow turn rate.
Another special problem for glider pilots is we learn and practice a sort of "seat-of-the-pants" flying. However, instrument flying is the polar opposite where one must completely ignore all kinetic and vestibular "feelings" and totally commit to believing the instruments even when every fiber in your your body is screaming the instruments are wrong - and your body WILL scream at you. Saying the "mind plays tricks" is a huge understatement.
Real single-pilot, partial-panel instrument flying is a deadly serious business not to be undertaken lightly. That's why pilots without the training and currency will almost always lose control of the aircraft as soon as visual references are lost.
What concerns me most about this thread is the emphasis on instruments themselves and not the training required to use them. Training is the key.
Old February 26th 13, 04:58 PM posted to rec.aviation.soaring
Dan Marotta
Good description. Well said!
"Bill D" wrote in message
rate.
understatement.
Old February 26th 13, 10:46 PM posted to rec.aviation.soaring
son_of_flubber
It's interesting to see how the TruTrak is marketed on the Cumulus website. He raises the "standard turn rate" issue.
http://www.cumulus-soaring.com/trutrak.htm
Old February 26th 13, 10:54 PM posted to rec.aviation.soaring
Bill D
I'm probably wrong saying 6 times too sensitive. A 1 minute T&B is the traditional glider instrument. However, think how large a 1 minute turn would be in a glider.
Old February 26th 13, 04:55 PM posted to rec.aviation.soaring
Dan Marotta
That's what's in my panel. Anybody want to give me $400 for it? It's been
in the panel for less than a year and has less than 30 minutes power up
time. Comes with harness, on-off switch, and connector.
"son_of_flubber" wrote in message
Old February 26th 13, 04:52 PM posted to rec.aviation.soaring
Dan Marotta
Gyros are not disallowed except in competition (in the USA, at least). I
have a functional J-8 attitude indicator in my hangar but it's too heavy and
power hungry to install in my panel. Not to mention that I've already
stated my firm intention to stay out of clouds.
I'd be a lot happier with the attitude indicator than I am with the TruTrak.
I'm not at all impressed with it.
"Alan" wrote in message
In article
son_of_flubber writes:
snip ...Why not equip gliders (with a turn and bank indicator) and
pilots
(with training) to safely handle a few minutes of cloud flying if it
is a
non-zero possibility
On Monday, February 25, 2013 10:50:52 AM UTC-5, Dan Marotta wrote:
That's a pretty naive question.
Pretty much ALL of my questions are naive due to my lack of much
experience and training. It's good for me to reminded of that from time
to time. Thanks for your answer.
The training would probably be a big deal as well -- the single
engine private pilot requirement is for 3 hours of flight training
in manuvering solely by reference to instruments. Even so, the
record of accidents after non-instrument rated pilots wander into
weather is not good.
I think that few would want to mandate these instruments be in
gliders.
On the other hand, I have read postings describing sudden rain
encounters that forced a pilot to suddenly and unexpectedly have
to fly by instrument reference, in conditions where visibility
had been substantial (perhaps 15 miles) a few instants before.
I can see where a running gyro instrument in the panel could be
a useful safety instrument for the glider pilot who was also an
instrument competent airplane pilot.
I would not want to see such be required, but it pains me to
see situations where such capability would be disallowed.
Alan
Old February 26th 13, 06:27 PM posted to rec.aviation.soaring
Peter von Tresckow
and power hungry to install in my panel. Not to mention that I've
already stated my firm intention to stay out of clouds.
TruTrak. I'm not at all impressed with it.
"Alan" wrote in message ...
In article
snip ...Why not equip gliders (with a turn and bank indicator) and pilots
(with training) to safely handle a few minutes of cloud flying if it is a
time to time. Thanks for your answer.
gliders.
Alan
Dan just out of curiosity, what about the trutrack don't you like???
Pete
Old February 27th 13, 12:12 AM posted to rec.aviation.soaring
Dan Marotta
I just don't have faith in it and the slip ball seems never to be centered.
Maybe I'm just out of practice... :-)
"Peter von Tresckow" wrote in message
In article
pilots
is a
gliders.
Alan
Pete
Old February 26th 13, 06:16 PM posted to rec.aviation.soaring
soartech[_2_]
* I would agree and disagree with Dan about this. *Obvious reasons
Just so incorrect information does not get propagated I have to
correct this statement.
Gyros are no longer expensive (now less than $10), heavy ( 1 oz.) or
power hungry.
Solid state gyros are now found in most "smart" phones and many other
places.
The old mechanical gyros are dead in the water (except for some very
specialized applications.)
Pulp Fiction, pt 3 - dare devil aces 1943 12.jpg (1/1) Mitchell Holman Aviation Photos 0 April 4th 07 01:54 PM
Pulp Fiction, pt 3 - dare devil aces 1934 01.jpg (1/1) Mitchell Holman Aviation Photos 0 April 4th 07 01:54 PM
Mounting a turn coordinator on the tail? Tim Auckland Instrument Flight Rules 25 August 6th 06 06:16 PM
Is a Turn Coordinator an electric motor or powered by fan? kickinwing Piloting 5 June 11th 05 12:25 PM
Opening up a turn coordinator Robert M. Gary Piloting 2 March 27th 04 06:52 AM
