Max Gross Weight Question
Old March 1st 13, 10:19 PM posted to rec.aviation.soaring
Tony[_5_]
Default Max Gross Weight Question
On Friday, March 1, 2013 4:13:22 PM UTC-6, 150flivver wrote:
Our glider has two max takeoff weights, one with water ballast and one with only pilot (134 lb difference). I just weighed the glider and the empty weight subtracted from the max takeoff weight (no water ballast) limits the useful load to 225. There's still some room to play with for the forward CG limit but it's the max weight with no water ballast that caps the pilot weight at 225. If the empty weight was lower and the CG was still within the limits, the glider manual references a max pilot weight of 245. Why is the glider legal with increased water weight but not increased pilot weight (assuming CG is still within limits)? I could see the rationale for an increased water weight gross if there was a requirement to jettison the water for landing but I could find no such restriction. So as far as I could tell, you're legal landing with water at a higher weight but not if the extra weight is pilot body mass.
because the water is in the wings and reduces the bending moment on the spar instead of weight in the cockpit which increases the moment.
cue to Holinghaus in Zulu Romeo: Good Start saying that 'these fiberglass gliders are so strong it is almost impossible to break them, in fact the heavier they are the safer they are'
i don't think i would take that too seriously. obey what is in the book
Should a W&B list gross weight? Andrew Gideon Owning 24 October 21st 05 11:03 PM
Gross Weight Fred Choate Piloting 153 July 14th 05 12:19 AM
Redline (inspired by Gross Weight) Jose Piloting 10 July 10th 05 06:35 PM
Max gross weight Chris Piloting 21 October 5th 04 08:22 PM
Empty/Gross weight Vs. Max. Pilot weight Flyhighdave Soaring 13 January 14th 04 04:20 AM
