On Sunday, March 3, 2013 10:18:02 PM UTC-6, wrote:
Any suggestions as to cause and fix? Bill Sounds like you have a leak in the TE line and they were both actually sensing static pressure. If hooked up backwards, they will operate backwards. If you had a leak between the capacity and the vario and a good connection between the vario and the TE probe, the vario would go full up and stay there until you land. Could be a missed connection in the plane, or maybe your probe didn't seal up in the fitting in the vertical tail Steve Leonard |
Agee with Steve, sounds like a T/E leak, could be anywhere from the back of
one of the instruments (or even inside one) to the probe connection on the fin. You can check if you can get hold of some instrument tubing, a T piece, a syringe and an old ASI. Connect pilot connection on ASI to one branch of the T, syringe to another and 3rd to T/E port in fin. Slowwly push in plunger on syringe, varios should read down. Stop pushing and varios will com back to zero if no leak and will read up if there's a leak. Up reading proprtional to size of leak. At 05:40 04 March 2013, Steve Leonard wrote: On Sunday, March 3, 2013 10:18:02 PM UTC-6, wrote: Any suggestions as to cause and fix? Bill Sounds like you have a leak in the TE line and they were both actually sens= ing static pressure. If hooked up backwards, they will operate backwards. = If you had a leak between the capacity and the vario and a good connection= between the vario and the TE probe, the vario would go full up and stay th= ere until you land. Could be a missed connection in the plane, or maybe your probe didn't seal = up in the fitting in the vertical tail Steve Leonard |
Here's a Wild New Idea! | -Mark- | Piloting | 1 | December 16th 10 10:14 PM |
Lawsuits gone wild! | AJ | Piloting | 24 | March 4th 08 07:12 AM |
Through the eye of the needle (long) | TTaylor07 at cc.usu.edu | Soaring | 2 | September 28th 05 12:48 PM |
Jumpy needle | Ludovic Launer | Soaring | 3 | April 5th 05 07:26 AM |
Cessna 172 with Wild Fuel Gauge Needle | jls | Owning | 26 | February 20th 04 05:56 AM |
