Before all the other good advice check that there isn't a loop of
unsupported tubing that could swing up and down in turbulence. At 18:59 04 March 2013, Craig Funston wrote: On Sunday, March 3, 2013 8:18:02 PM UTC-8, wrote: First flight today in glider with LX 7007 and Winter varios. Needles on both the LED vario and the Winter mechanical would swing wildly from 10 kts up to 10 kts down all thru the flight- mostly in cruise, but also in the early phase of thermalling. Needle and LED display seemed synchronous. Both would settle down to give reasonable readings once established in a thermal. I believe both are plumbed to the same TE probe (an unusually long probe with tee at the end-- not the usual bent up variety). Can't be a computer or electrical problem as the Winter would not be affected. Any suggestions as to cause and fix? Bill If the receptacle in the fin is designed for Prandtl Tubes, it has two ports. You need to plug the unused port if all you are using is a standard TE probe. Otherwise there's a very big leak. Best regards, Craig |
Here's a Wild New Idea! | -Mark- | Piloting | 1 | December 16th 10 10:14 PM |
Lawsuits gone wild! | AJ | Piloting | 24 | March 4th 08 07:12 AM |
Through the eye of the needle (long) | TTaylor07 at cc.usu.edu | Soaring | 2 | September 28th 05 12:48 PM |
Jumpy needle | Ludovic Launer | Soaring | 3 | April 5th 05 07:26 AM |
Cessna 172 with Wild Fuel Gauge Needle | jls | Owning | 26 | February 20th 04 05:56 AM |
