Another piece of advice.
Ignore the incipient flame war and just look at the software (and maybe talk to some users) +1 Both should be able to connect to Condor or some other simulator capable of sending NMEA output over RS232 or TCP/IP. Perhaps this is suitable to simulate a flight for yourself and see how you like each program. |
I cannot comment on the original question about XCSoar versus LK8000
and which to use as I have only flown with SeeYou Mobile on the Oudie (and GlideNav II on a HP PDA). But, here are links (and links to links) to good descriptions on the Naviter forum on how to have either tool running on the same Oudie - which would allow you to have the best of both worlds and to trial both tools. http://forum.naviter.com/threads/479...r-on-the-Oudie http://forum.naviter.com/threads/256...ghlight=xcsoar Good luck, John |
I would recommend making a fairly quick choice between the software options and putting the time into studying the chosen version. They will all do your job well. If you spend too long choosing you will not only waste time but also end up confused.
On Monday, March 11, 2013 10:13:55 AM UTC-5, waremark wrote:
I would recommend making a fairly quick choice between the software options and putting the time into studying the chosen version. They will all do your job well. If you spend too long choosing you will not only waste time but also end up confused. So, Max, Paolo or US pilots: Is either of these two packages useable in a US contest? Do they depict US start, turnpoint and finish definitions, tell you if you're under the top for 2 minutes, help plan time completion for area and mat tasks, compute final glides to a finish cylinder with a minimum altitude, compute final glides around additional turnpoints (mat)? Can you input a task in less than 15 minutes? Is there a quick task A task B option (almost all in air task changes are now A to B)? I tried xcsoar many years ago. Charlie Spratt changed the task in the air. 15 minutes later on my second reboot, I swore it off. Is contest task entry any easier than back then? If not, is anyone working on a "US contest" package for either program? Please no flame wars on how stupid our rules are for using cylinders, 2 minute rules, in air task changes, etc. The rules are what they are. The question is, can this software help a pilot to deal with the rules as they are? John Cochrane |
On Monday, March 11, 2013 5:22:15 PM UTC+1, wrote:
Do they depict US start, turnpoint and finish definitions Sorry, I don't know US task rules. If there's anything missing, you should write a ticket (http://bugs.xcsoar.org/newticket). tell you if you're under the top for 2 minutes I havn't heard of that feature, but then again, I don't fly contests. (I'm just one of several XCSoar developers, I don't know every part of XCSoar) help plan time completion for area and mat tasks Yes for AAT, never heard of "MAT". compute final glides to a finish cylinder with a minimum altitude Yes. compute final glides around additional turnpoints (mat)? Again, don't about about MAT. Can you input a task in less than 15 minutes? It usually takes me a minute on my Streak. Is there a quick task A task B option (almost all in air task changes are now A to B)? You mean you have two active tasks, and switch between the two? No, but thanks to our excellent task engine, that would not be hard to implement. If it's really useful for contest pilots. I tried xcsoar many years ago. Charlie Spratt changed the task in the air. 15 minutes later on my second reboot, I swore it off. Is contest task entry any easier than back then? The task engine and the task editor have been rewritten from scratch in XCSoar 6.0. XCSoar has come a very long way since the dark 5.x days. If not, is anyone working on a "US contest" package for either program? No, our goal is to have everything in the "mainline". So if any US pilot decides to hack XCSoar code, please contact us for merging the new features. |
On Monday, March 11, 2013 11:32:55 AM UTC-5, Max Kellermann wrote:
On Monday, March 11, 2013 5:22:15 PM UTC+1, wrote: Do they depict US start, turnpoint and finish definitions Sorry, I don't know US task rules. If there's anything missing, you should write a ticket (http://bugs.xcsoar.org/newticket). tell you if you're under the top for 2 minutes I havn't heard of that feature, but then again, I don't fly contests. (I'm just one of several XCSoar developers, I don't know every part of XCSoar) help plan time completion for area and mat tasks Yes for AAT, never heard of "MAT". compute final glides to a finish cylinder with a minimum altitude Yes. compute final glides around additional turnpoints (mat)? Again, don't about about MAT. Can you input a task in less than 15 minutes? It usually takes me a minute on my Streak. Is there a quick task A task B option (almost all in air task changes are now A to B)? You mean you have two active tasks, and switch between the two? No, but thanks to our excellent task engine, that would not be hard to implement. If it's really useful for contest pilots. I tried xcsoar many years ago. Charlie Spratt changed the task in the air. 15 minutes later on my second reboot, I swore it off. Is contest task entry any easier than back then? The task engine and the task editor have been rewritten from scratch in XCSoar 6.0. XCSoar has come a very long way since the dark 5.x days. If not, is anyone working on a "US contest" package for either program? No, our goal is to have everything in the "mainline". So if any US pilot decides to hack XCSoar code, please contact us for merging the new features.. Max, I loaded every one of the above mentioned software packages on my new Avier (V2 sold by WingsAndWheels) plus Winpilot Pro and SeeYou Mobile for testing. Still trying to decide if I should abandon WinPilot which works very well for US contest flying. However, running XCSoar on my new Nexus 7 just blows me away. The graphics and speed are unbelievable. Problem is, the Nexus is a little too big for the cockpit but I think the screen is very readable in sunlight with brighness turned up. Thanks for porting XCS for Android! I also use the Nexus and XCS to display flight data in Condor via Bluetooth. Herb Kilian |
On Monday, March 11, 2013 12:22:15 PM UTC-4, wrote:
On Monday, March 11, 2013 10:13:55 AM UTC-5, waremark wrote: I would recommend making a fairly quick choice between the software options and putting the time into studying the chosen version. They will all do your job well. If you spend too long choosing you will not only waste time but also end up confused. So, Max, Paolo or US pilots: Is either of these two packages useable in a US contest? Do they depict US start, turnpoint and finish definitions, tell you if you're under the top for 2 minutes, help plan time completion for area and mat tasks, compute final glides to a finish cylinder with a minimum altitude, compute final glides around additional turnpoints (mat)? Can you input a task in less than 15 minutes? Is there a quick task A task B option (almost all in air task changes are now A to B)? I tried xcsoar many years ago. Charlie Spratt changed the task in the air.. 15 minutes later on my second reboot, I swore it off. Is contest task entry any easier than back then? If not, is anyone working on a "US contest" package for either program? Please no flame wars on how stupid our rules are for using cylinders, 2 minute rules, in air task changes, etc. The rules are what they are. The question is, can this software help a pilot to deal with the rules as they are? John Cochrane I spent most of three seasons using XCS for US contests. On Ipaq 3950s to start, later on Dell Streak 5. Nine or ten contests IIRC. Something important was always busted in software. Start rules, AAT task optimizer, little things :-/. I wrote lots of trouble tickets. Some got acted on right away, some never. I haven't used XCS since version 6.3. There's a timer that can be used to tell you how long you have been under max height. When things work in XCS, they work well. Task editing is easy on the ground. Task editing in flight depends on your interface, and all of the hardware that I am familiar with that runs XCSoar is touch screen driven. I grew to hate touch screens in flight. My big problem with a touch screen is that I have to look the display for every single poke. This sounds trivial. In fact it adds up to a lot of distraction. There are better solutions for racing. The two that I am aware of that demonstrably work (i.e. guys win with them, a lot) are SN10 and ClearNav. The reason that these devices work better is that they take about a quarter the head down time that XCSoar does. Better user interface, easier to read displays in about equal parts. Neither attempts to do nearly as much as XCSoar can, but an awful lot of what XCSoar can do isn't helpful for racing.. The best clues to efficient soaring are outside the window. Less distraction equals better performance in my cockpit, and probably yours too. By way of disclosure, I work part time for CNi, however this post is my personal opinion, informed by experience. Evan Ludeman / T8 |
On Monday, March 11, 2013 7:11:25 PM UTC+1, Evan Ludeman wrote:
I spent most of three seasons using XCS for US contests. On Ipaq 3950s to start, later on Dell Streak 5. Nine or ten contests IIRC. Something important was always busted in software. Start rules, AAT task optimizer, little things :-/. I wrote lots of trouble tickets. Some got acted on right away, some never. Some never? The following points to a exhaustive list of all of your tickets we havn't worked on yet: http://bugs.xcsoar.org/query?status=...%40g mail.com This is exactly one ticket, one that can't be any less serious. Yes, you found a lot of problems over the years (totalling 24), and that was your contribution to a better XCSoar, it helped a lot. Thousands of eyes find thousands of problems in such a complex software (nearly 26,000 users on Android alone). We do our best to deliver high quality to all those pilots, and we need input from people like you. But please be honest. I know you want to drop some advertisement for your employer, but don't exaggerate the severity and number of open bugs. |
On Monday, March 11, 2013 2:33:19 PM UTC-4, Max Kellermann wrote:
On Monday, March 11, 2013 7:11:25 PM UTC+1, Evan Ludeman wrote: I spent most of three seasons using XCS for US contests. On Ipaq 3950s to start, later on Dell Streak 5. Nine or ten contests IIRC. Something important was always busted in software. Start rules, AAT task optimizer, little things :-/. I wrote lots of trouble tickets. Some got acted on right away, some never. Some never? The following points to a exhaustive list of all of your tickets we havn't worked on yet: http://bugs.xcsoar.org/query?status=...%40g mail.com This is exactly one ticket, one that can't be any less serious. Yes, you found a lot of problems over the years (totalling 24), and that was your contribution to a better XCSoar, it helped a lot. Thousands of eyes find thousands of problems in such a complex software (nearly 26,000 users on Android alone). We do our best to deliver high quality to all those pilots, and we need input from people like you. But please be honest. I know you want to drop some advertisement for your employer, but don't exaggerate the severity and number of open bugs. Actually, inability to d/l waypoints to a 302 is a pretty serious defect *for me* since I use the 303 display routinely and travel to many different soaring sites (but only because the 302 has small memory and no way to manage multiple waypoint sets). Without that capability, I have to drag out a laptop, pop the canopy off to get under the panel, etc. That much of the interface was all very handy with the little Ipags that could run the Cambridge utility. The fact remains *every* release of XCSoar I used had significant bugs that affected its utility in competition. If you've fixed some of the tickets I left behind since I bothered to look (roughly last June), thank you, perhaps it will help others. Evan Ludeman / T8 |
XCSoar or LK8000? | Dan Marotta | Soaring | 18 | August 11th 16 02:54 PM |
Announcing LK8000 v4.0 | pcool | Soaring | 2 | February 16th 13 08:20 PM |
Expanding on LK8000 | [email protected] | Soaring | 12 | January 23rd 13 06:50 PM |
Brief review of Android XCSoar on the Streak 5 and LK8000 on the MIO 400 | Mike[_8_] | Soaring | 7 | April 1st 11 10:22 PM |
LK8000 questions | Andy[_1_] | Soaring | 9 | March 15th 10 11:10 AM |
