Calculating G Forces from IGC file?
Old March 13th 13, 03:42 PM posted to rec.aviation.soaring
JohnDeRosa
Default Calculating G Forces from IGC file?
Poul - Wow. That was intense. I agree that this isn't just an
exercise in the vertical component.
John - I think you are pointing me in the right direction.
I came up with this math for just the vertical component. Does this
math seem correct?
RateofClimb (vertical speed) m/s = (BRecord_Altitude_N meters -
BRecord_Altitude_N+1 meters) / BRecord_interval*
G force = (RateofClimb_N m/sec - RateofClimb_N+1 m/sec) /
(BRecord_interval*) / (9.80665 m/sec2)
* Typical IGC log file interval has B record entries every 4 seconds.
Yours may be different. And in the C302 if you hit the event button,
the interval always goes to 1 second.
At first glance the second division by the BRecord_Interval seems
wrong, but the BRecord_Altitude's are spaced by the BRecord_interval
AND the RateofClimb's are also spaced by the BRecord_interval.
I looked at a flight in which I remembered the vario going to +17
knots (whoop!). I calculated the G force at 8.4. Seems about right.
This gives a four second averaging so no telling what instantaneous
rates are. So for those flying a ridge where they are getting bounced
up/down repeatedly, this 4 second calculation wouldn't say much about
what you are experiencing. Makes me want to change my log rate to 1
second! Or buy a G meter!
If my math is correct (big IF) then I will publish my calculations so
anyone can plug in their B records and calculate/graph the results.
- John
Old March 13th 13, 04:30 PM posted to rec.aviation.soaring
JohnDeRosa
FYI - When you hit the event button on the Cambridge 302 via remote
switch required (and the Cambridge 302A via the front panel PEV
switch?) it will record 15 fixes at 1 second intervals.
This is useful when you are only going to touch a turnpoint cylinder
and don't want to wait around for X seconds (your standard recording
interval) to make sure you get a valid fix. I have heard of people
that missed a turnpoint due to this.
Do other flight recorders also have this feature?
- John
Old March 14th 13, 03:19 PM posted to rec.aviation.soaring
Andrew Corrigan[_2_]
Buy the G-meter to get the actual data because the logic you have used is
not accurate.
First, you need a real time data recorder for the method you have chosen to
sample the event. Within 4 seconds you could load and unload G without the
event being recorded on the logger. Even with 1 second you would not
capture all of the data accuately.
Furthermore, I doubt the positional data being recorded is accurate enough
for what you are doing. There is a tolerance on the GPS signal. It is my
understanding that height position is a lot worse than Lat/Long.
In addition, I don't beleive your formula is taking into account the
deceleration caused by the G loading. High G's decelerate a glider. Looked
like your formula was straight line.
Finally, I doubt 8.4 G's is correct because this is a lot. A recreational
pilot would black out well before you reach this amount. Also, only the
high end aerobatic gliders could with stand over 8 Gs. A typical xcountry
glider is not rated for 8 G's.
As you said, buy a G meter.
Andrew
math seem correct?
- John
Old March 14th 13, 10:47 PM posted to rec.aviation.soaring
8 Gs seems like a lot. And position error will indeed maginfy second derivatives. I'd first fit a smoothed flight path through 10 points or so, then take second derivatives of the smoothed function. Just run a regression with a quadratic function for the x y and z coordinates separately +/- say 5 points, and use the coefficient on the quadratic term to get local acceleration.
John Cochrane
Old March 15th 13, 02:08 AM posted to rec.aviation.soaring
John Cochrane
I think 4 second intervals is pretty tough for trying to generate a view of acceleration in the vertical plane. You need three points to fit a quadratic which is what you need to measure acceleration. 3x4 =12 seconds. Take a look at this to see what happens when you pull just 3 Gs for 12 seconds.
http://www.youtube.com/watch?v=9aDJLDQ-5QU
I think you need a higher sample rate to come up with anything for normal maneuvering. Certainly measuring a circle will give you horizontal centripetal acceleration, but circling gives you a fair number of data points without getting inverted.
9B
Old March 15th 13, 06:17 AM posted to rec.aviation.soaring
Morgan[_2_]
I have a little toy app on my iPhone called "Roller Coaster Physics" that is essentially a g-meter recorder that was free if I recall right.
I don't know how accurate the meters in an iPhone are, but you could try recording some maneuvers and using it as a sanity check for your calcs. I think I downloaded it for use in the plane and pretty much forgot about it for 3 years until I saw this thread.
Morgan
John Cochrane
I think 4 second intervals is pretty tough for trying to generate a view of acceleration in the vertical plane. You need three points to fit a quadratic which is what you need to measure acceleration. 3x4 =12 seconds. Take a look at this to see what happens when you pull just 3 Gs for 12 seconds..
9B
Calculating Headwind/Tailwind component Ramy Soaring 13 March 15th 12 01:26 AM
Help calculating Speed To Fly for headwind and tailwind Tim Taylor Soaring 23 June 2nd 10 05:52 PM
I need help Comparing and Calculating final glide performance Udo Soaring 8 November 2nd 09 03:15 PM
Procedure for calculating weight and balance Mxsmanic Piloting 153 January 30th 07 07:35 PM
Calculating CL for various wing shapes ian .at.bendigo Home Built 0 August 28th 03 12:47 PM
