Is the 787 a failure ?
Old March 7th 13, 04:46 PM posted to rec.aviation.piloting,rec.crafts.metalworking,rec.aviation.military,talk.politics.misc,alt.society.labor-unions
Bradley K. Sherman
Default Is the 787 a failure ?
NTSB Has nothing, nada, zilch:
| (Reuters) - The National Transportation Safety Board is
| examining the certification and testing of the lithium-ion
| battery system on the Boeing Co 787, the NTSB said on
| Thursday.
| The NTSB's "interim factual report" on a January battery
| fire in Boston did not include any conclusions about the
| cause of the fire, which contributed to the plane's
| grounding by regulators.
http://www.reuters.com/article/2013/03/07/boeing-dreamliner-ntsb-idUSWEN0083S20130307
Here's what NTSB released (warning, 500 pages):
http://dms.ntsb.gov/pubdms/search/hitlist.cfm?docketID=54251&CFID=2871&CFTOKEN=67900 912
--bks
  #172
Old March 7th 13, 10:28 PM posted to rec.aviation.piloting,rec.crafts.metalworking,rec.aviation.military,talk.politics.misc,alt.society.labor-unions
Bradley K. Sherman
| * Boeing outsourced both the analysis and testing of the
| battery system's safety to its subcontractor, Thales of
| France, and to the battery maker, GS Yuasa of Japan.
| * Testing of the battery charging unit (BCU) system was
| done by a Thales sub-contractor, Securaplane of Tucson,
| Ariz.
| Early developmental testing of this system resulted in a
| major battery fire in 2006 that burned down a Securaplane
| building. After this, actual batteries were used only for
| isolated tests, with most of the testing instead using
| equipment that provided an electrical load representative
| of what a battery would provide.
| The NTSB notes that there doesn't seem to have been any
| testing of the charging system and battery together as an
| integrated system inside the airplane.
http://seattletimes.com/html/businesstechnology/2020505762_ntsb787reportxml.html
--bks
  #173
Old March 11th 13, 11:42 PM posted to rec.aviation.piloting,rec.crafts.metalworking,rec.aviation.military,talk.politics.misc,alt.society.labor-unions
Bradley K. Sherman
| NEW YORK - The stock market crept higher Monday, pushing
| the Dow Jones industrial average to its seventh straight
| day of gains.
| Boeing was the Dow's top stock, surging 2 percent. A Boeing
| executive reportedly said he's confident the aircraft maker
| has figured out a fix for the battery problems that have
| grounded the 787 Dreamliner.
http://www.dailymail.com/Business/201303110163
--bks
  #174
Old March 12th 13, 11:23 PM posted to rec.aviation.piloting,rec.crafts.metalworking,rec.aviation.military,talk.politics.misc,alt.society.labor-unions
Bradley K. Sherman
FAA Press Release:
| WASHINGTON, D.C. - The Federal Aviation Administration
| (FAA) today approved the Boeing Commercial Airplane
| Company's certification plan for the redesigned 787 battery
| system, after thoroughly reviewing Boeing's proposed
| modifications and the company's plan to demonstrate that
| the system will meet FAA requirements. The certification
| plan is the first step in the process to evaluate the 787's
| return to flight and requires Boeing to conduct extensive
| testing and analysis to demonstrate compliance with the
| applicable safety regulations and special conditions.
| The FAA will approve the redesign only if the company
| successfully completes all required tests and analysis to
| demonstrate the new design complies with FAA requirements.
| The FAA's January 16, 2013 airworthiness directive, which
| required operators to temporarily cease 787 operations, is
| still in effect, and the FAA is continuing its
| comprehensive review of the 787 design, production and
| manufacturing process.
http://www.faa.gov/news/press_releases/news_story.cfm?newsId=14394
--bks
  #175
Old March 13th 13, 11:24 PM posted to rec.aviation.piloting,rec.crafts.metalworking,rec.aviation.military,talk.politics.misc,alt.society.labor-unions
Bradley K. Sherman
There will be a live Boeing technical briefing about the 787 "fix"
webcast from Tokyo, Thursday 14 March, 6 pm Pacific:
http://787updates.newairplane.com/Certification/Webcast
--bks
  #176
Old March 22nd 13, 03:00 AM posted to rec.aviation.piloting,rec.crafts.metalworking,rec.aviation.military,talk.politics.misc,alt.society.labor-unions
Bradley K. Sherman
Who are you gonna believe, Boeing or your own lying eyes?
| Boeing Co. (BA)'s assertion that U.S. investigators ruled
| out a fire within the battery case of a Japan Airlines Co.
| (9201) 787 is premature, a National Transportation Safety
| Board spokesman said.
| Investigators examining the Jan. 7 fire aboard the
| Dreamliner in Boston haven't ruled out that flames erupted
| within the lithium-ion battery container, Peter Knudson
| said today in response to questions about the issue.
| Michael Sinnett, Boeing's chief project engineer, said in
| the briefing that investigators hadn't found evidence of
| flames within the Boston battery's container box, an
| indication it worked as designed to limit damage from a
| battery failure.
| A witness who tried to fight the Jan. 7 fire said he saw 3-
| inch (7.6-centimeter) flames outside the lithium-ion
| battery, and the NTSB has found evidence of high
| temperatures within battery cells that failed, according to
| preliminary safety-board documents released March 7.
http://www.businessweek.com/news/2013-03-15/ntsb-contradicts-boeing-claim-of-no-fire-in-787-battery
--bks
  #177
Old March 22nd 13, 06:55 AM posted to rec.aviation.piloting,rec.crafts.metalworking,rec.aviation.military,talk.politics.misc,alt.society.labor-unions
Mr. B1ack
On Fri, 22 Mar 2013 03:00:07 +0000 (UTC), (Bradley K.
| battery failure.
--bks
Gawd ... is THIS thread still going on ???????????/
Yes, the 787 is a failure.
Put it this way ... after hearing about its problems *I* will
NEVER fly on one - ever.
And I'm hardly the only one who feels this way.
Not interested in burning to death over the Pacific ....
  #178
Old March 22nd 13, 07:38 AM posted to rec.aviation.piloting,rec.crafts.metalworking,rec.aviation.military,talk.politics.misc,alt.society.labor-unions
Daryl[_2_]
| battery failure.
--bks
The conventional Batteries are sometimes called Sealed Lead Acid
Batteries but they are actually AGM batteries. Less time between
replacements, requires a heated and cooled area but is the most
dependable. If that is all that is keeping the 787 from flying, it's a
pretty simple fix.
Daryl
  #179
Old March 22nd 13, 09:23 AM posted to rec.aviation.piloting,rec.crafts.metalworking,rec.aviation.military,talk.politics.misc,alt.society.labor-unions
Keith W[_4_]
battery failure.
--bks
Modern passenger aircraft normally use Nickel Cadmium batteries
Less time between
a pretty simple fix.
Not necessarily as that may need recertification which is a complex and
lengthy since the batteries would be heavier and take up more
space.
Keith
  #180
Old March 22nd 13, 11:08 AM posted to rec.aviation.piloting,rec.crafts.metalworking,rec.aviation.military,talk.politics.misc,alt.society.labor-unions
Daryl[_2_]
battery failure.
--bks
Which are prone to a lot of problems. And it's old tech. Now for the
real negatives. If you overcharge them, they overheat. If you let them
go down below 20% they will need to be taken out and charged very, very
slowly with a special charger. They are very susceptible to temperature
ranges. They are the heaviest of the Non Lead Acid batteries, their
life span is almost equal to the sealed lead acid if you don't count the
fact they damage easy. The cost is more than the AGM.
The AGM is just now finding it's way into the aircraft industry. Of
course, it has been somewhat over looked because of the Lithiums. But
it appears that small aircraft that are worried about initial building
costs are not overlooking them.
What they are looking at is the replacement hours on the Lithiums. They
start out at 800 charges and go to 2000 charges depending on the type of
Lithium. The weights in comparison to the AGM is anywhere 3 times to 5
times lighter. But the cost is at least 5 times the cost.
Less time between
space.
They are going to have to be re certified anyway. The AGM isn't that
much larger and it's pretty well proven in the Electric Vehicles to day.
IT does the job if you keep it over 50% just like clockwork and can
last at least 2 to 5 years without going below 50% charge if you keep
them above freezing and below 100 degrees (the same as the Lithiums). I
use AGMs on a daily basis and my battery provider says I am the hardest
on batteries he's ever seen. I am getting ready to do another build
that uses the heavier Deep Cell which is designed to put up with my
punishement. But the AGMs are more rugged than the Lithiums that I also
use.
Nacads also work but for about one run into town before they overheat.
Ever seen a Nacad blow up? IT's pretty anticlimatic. They burst and
make a mess out of everything around it. And it's caustic. Same goes
for a Lithium except they will go into flame and feed the flame until
all the liquid is used up. I have never had a case break open on an
AGM. I've crashed em, dump em, drop em, used them for Rocky Mountain
Offroad, and more.
I can see that the Deep Cell Sealed Lead Acid should be as tough and
have a longer run time but they are twice as heavy. The lifespan of the
Deep Cell the way I use batteries should be as high as the Lithium and
cost less. But the weight means only my 3 wheelers will use them. They
just don't make 10 to 15 amp deep cells. But they do make a very solid
35 amp at twice the weight and size of a 12 amp AGM.
I am just not sold on Lithiums and I am certainly not sold on Nicads.
The Airline Aircraft Industry can use the AGMS and have less problems,
almost the same run time as the lower Lithium Mag batteries and save a
bunch of money.
Daryl
ATC failure in Memphis Mxsmanic Piloting 77 October 11th 07 03:50 PM
The Failure of FAA Diversity FAA Civil Rights Piloting 35 October 9th 07 06:32 PM
The FAA Failure FAA Civil Rights Instrument Flight Rules 0 October 8th 07 05:57 PM
Failure #10 Capt.Doug Piloting 7 April 13th 05 02:49 AM
Another Bush Failure WalterM140 Military Aviation 8 July 3rd 04 02:23 AM
