Tail Tank pull handle....ideas
Old March 14th 13, 02:41 PM posted to rec.aviation.soaring
Dan Marotta
Default Tail Tank pull handle....ideas
In the LAK-17a they use a push-pull handle which slides in an "L" shaped
slot in a metal plate. The tail tank (wings use the same setup with a
separate lever) is held closed by placing the lever in the short slot,
opened by pulling into the long slot and then aft.
On Wednesday, March 13, 2013 2:31:08 PM UTC-4, Gregg Leslie wrote:
Hi guys, I'm looking for a sliding dump handle idea, it needs to travel 2
inches, maybe a notched plate with a handle....any ideas or drawings? GL
In my 20C the stock valve acuators were small over center levers. I just
made a hook to go over one of them to operate the tail valve cable.
Unhooked to separate fuctions if needed.
UH
Just pull the little red handle! JJ Sinclair Soaring 65 September 5th 10 11:57 AM
LS6-b tail tank leak fix kirk.stant Soaring 2 August 19th 08 01:39 AM
Getting a handle on the tail dolly Tuno Soaring 7 April 26th 08 07:28 AM
Ventus B tail tank add on Cliff Hilty Soaring 1 October 7th 04 03:53 PM
Pull plane by tail hook Tarif Halabi Owning 19 February 24th 04 02:27 PM
