Calculating G Forces from IGC file?
Old March 15th 13, 02:08 AM posted to rec.aviation.soaring
Default Calculating G Forces from IGC file?
On Thursday, March 14, 2013 3:47:30 PM UTC-7, wrote:
8 Gs seems like a lot. And position error will indeed maginfy second derivatives. I'd first fit a smoothed flight path through 10 points or so, then take second derivatives of the smoothed function. Just run a regression with a quadratic function for the x y and z coordinates separately +/- say 5 points, and use the coefficient on the quadratic term to get local acceleration.
John Cochrane
I think 4 second intervals is pretty tough for trying to generate a view of acceleration in the vertical plane. You need three points to fit a quadratic which is what you need to measure acceleration. 3x4 =12 seconds. Take a look at this to see what happens when you pull just 3 Gs for 12 seconds.
http://www.youtube.com/watch?v=9aDJLDQ-5QU
I think you need a higher sample rate to come up with anything for normal maneuvering. Certainly measuring a circle will give you horizontal centripetal acceleration, but circling gives you a fair number of data points without getting inverted.
9B
Old March 15th 13, 06:17 AM posted to rec.aviation.soaring
Morgan[_2_]
I have a little toy app on my iPhone called "Roller Coaster Physics" that is essentially a g-meter recorder that was free if I recall right.
I don't know how accurate the meters in an iPhone are, but you could try recording some maneuvers and using it as a sanity check for your calcs. I think I downloaded it for use in the plane and pretty much forgot about it for 3 years until I saw this thread.
Morgan
John Cochrane
I think 4 second intervals is pretty tough for trying to generate a view of acceleration in the vertical plane. You need three points to fit a quadratic which is what you need to measure acceleration. 3x4 =12 seconds. Take a look at this to see what happens when you pull just 3 Gs for 12 seconds..
9B
Calculating Headwind/Tailwind component Ramy Soaring 13 March 15th 12 01:26 AM
Help calculating Speed To Fly for headwind and tailwind Tim Taylor Soaring 23 June 2nd 10 05:52 PM
I need help Comparing and Calculating final glide performance Udo Soaring 8 November 2nd 09 03:15 PM
Procedure for calculating weight and balance Mxsmanic Piloting 153 January 30th 07 07:35 PM
Calculating CL for various wing shapes ian .at.bendigo Home Built 0 August 28th 03 12:47 PM
