Hi Paul,
I don't have the time to develop the C+ skills to work on getting communication working between the L-NAV and XCSoar right now so I probably don't need the comm spec. I do know a pilot that has sent me something of the sentence structure that the L-NAV uses when communicating with the GPS Nav. I think that could possibly be used for getting data into XCSoar, but I haven't seen what all it can support. I actually am quite happy leaving them disconnected from each other at this point. It allows me to leave XCSoar at a higher MC value or at least with a larger polar degradation buffer and experiment with the L-Nav MC value for more aggressive flying. I do miss XCSoar having real-time wind info on a long glide though. Morgan On Friday, March 15, 2013 7:10:59 PM UTC-7, Paul Remde wrote: Hi Morgan, By "L-NAV" do you mean an L-NAV and GPS-NAV combination? The L-NAV does not send any data out to soaring flight software. It can send data to a GPS-NAV. The GPS-NAV then sends the vario and GPS data out to the soaring flight software. I have the L-NAV and GPS-NAV dataport specification if you need it. Best Regards, Paul Remde Cumulus Soaring, Inc. __________________________ "Morgan" wrote in message ... I have XCSoar running on a Dell Streak 5 and wanted to look into connecting to the L-Nav in my glider. I have an IOIO board, but I believe the real problem is that the L-Nav doesn't use the same protocol as the 302. XCSoar essentially doesn't have the right driver for the L-Nav and so far none of the developers have a need to configure a driver for the L-Nav or the hardware to actually do it. I suspect there are many potential users of that configuration, but it will take a user with the drive and the skillset to augment the XCSoar code with the necessary pieces to support the L-Nav. Hans has some useful info on his website about connecting GPS data to an L-Nav. https://sites.google.com/site/threeuniform/lnav Morgan On Monday, March 11, 2013 8:04:08 AM UTC-7, Dan Marotta wrote: I just had a quick look behind one's panel but it doesn't look like there's any place to plug in the serial to Bluetooth device without unplugging something else. Maybe the GPS control head... " On Monday, March 11, 2013 12:51:59 AM UTC+1, Dan Marotta wrote: Can their Androids be interfaced to the LNAV via K6-BT or IOIO? I have never used any of these products, but usually K6Bt and IOIO works just like a cable would. |
Can't you read the wind from the LNAV/GPSNAV and manually input it into
XCSoar? Not realtime, but pretty close. "Morgan" wrote in message ... Hi Paul, I don't have the time to develop the C+ skills to work on getting communication working between the L-NAV and XCSoar right now so I probably don't need the comm spec. I do know a pilot that has sent me something of the sentence structure that the L-NAV uses when communicating with the GPS Nav. I think that could possibly be used for getting data into XCSoar, but I haven't seen what all it can support. I actually am quite happy leaving them disconnected from each other at this point. It allows me to leave XCSoar at a higher MC value or at least with a larger polar degradation buffer and experiment with the L-Nav MC value for more aggressive flying. I do miss XCSoar having real-time wind info on a long glide though. Morgan On Friday, March 15, 2013 7:10:59 PM UTC-7, Paul Remde wrote: Hi Morgan, By "L-NAV" do you mean an L-NAV and GPS-NAV combination? The L-NAV does not send any data out to soaring flight software. It can send data to a GPS-NAV. The GPS-NAV then sends the vario and GPS data out to the soaring flight software. I have the L-NAV and GPS-NAV dataport specification if you need it. Best Regards, Paul Remde Cumulus Soaring, Inc. __________________________ "Morgan" wrote in message ... I have XCSoar running on a Dell Streak 5 and wanted to look into connecting to the L-Nav in my glider. I have an IOIO board, but I believe the real problem is that the L-Nav doesn't use the same protocol as the 302. XCSoar essentially doesn't have the right driver for the L-Nav and so far none of the developers have a need to configure a driver for the L-Nav or the hardware to actually do it. I suspect there are many potential users of that configuration, but it will take a user with the drive and the skillset to augment the XCSoar code with the necessary pieces to support the L-Nav. Hans has some useful info on his website about connecting GPS data to an L-Nav. https://sites.google.com/site/threeuniform/lnav Morgan On Monday, March 11, 2013 8:04:08 AM UTC-7, Dan Marotta wrote: I just had a quick look behind one's panel but it doesn't look like there's any place to plug in the serial to Bluetooth device without unplugging something else. Maybe the GPS control head... " On Monday, March 11, 2013 12:51:59 AM UTC+1, Dan Marotta wrote: Can their Androids be interfaced to the LNAV via K6-BT or IOIO? I have never used any of these products, but usually K6Bt and IOIO works just like a cable would. |
Dan,
Yes, this is what I do if the situation warrants it, like wave or significant winds. Since I have the full L-NAV, GPS-NAV setup I can rely on that for final glide type info. With 6+ of XCSoar, they really improved the easy of manual wind entry so you are correct, it's pretty trivial. Morgan On Saturday, March 16, 2013 8:55:25 AM UTC-7, Dan Marotta wrote: Can't you read the wind from the LNAV/GPSNAV and manually input it into XCSoar? Not realtime, but pretty close. "Morgan" wrote in message ... Hi Paul, I don't have the time to develop the C+ skills to work on getting communication working between the L-NAV and XCSoar right now so I probably don't need the comm spec. I do know a pilot that has sent me something of the sentence structure that the L-NAV uses when communicating with the GPS Nav. I think that could possibly be used for getting data into XCSoar, but I haven't seen what all it can support. I actually am quite happy leaving them disconnected from each other at this point. It allows me to leave XCSoar at a higher MC value or at least with a larger polar degradation buffer and experiment with the L-Nav MC value for more aggressive flying. I do miss XCSoar having real-time wind info on a long glide though. Morgan On Friday, March 15, 2013 7:10:59 PM UTC-7, Paul Remde wrote: Hi Morgan, By "L-NAV" do you mean an L-NAV and GPS-NAV combination? The L-NAV does not send any data out to soaring flight software. It can send data to a GPS-NAV. The GPS-NAV then sends the vario and GPS data out to the soaring flight software. I have the L-NAV and GPS-NAV dataport specification if you need it. Best Regards, Paul Remde Cumulus Soaring, Inc. __________________________ "Morgan" wrote in message ... I have XCSoar running on a Dell Streak 5 and wanted to look into connecting to the L-Nav in my glider. I have an IOIO board, but I believe the real problem is that the L-Nav doesn't use the same protocol as the 302. XCSoar essentially doesn't have the right driver for the L-Nav and so far none of the developers have a need to configure a driver for the L-Nav or the hardware to actually do it. I suspect there are many potential users of that configuration, but it will take a user with the drive and the skillset to augment the XCSoar code with the necessary pieces to support the L-Nav. Hans has some useful info on his website about connecting GPS data to an L-Nav. https://sites.google.com/site/threeuniform/lnav Morgan On Monday, March 11, 2013 8:04:08 AM UTC-7, Dan Marotta wrote: I just had a quick look behind one's panel but it doesn't look like there's any place to plug in the serial to Bluetooth device without unplugging something else. Maybe the GPS control head... " On Monday, March 11, 2013 12:51:59 AM UTC+1, Dan Marotta wrote: Can their Androids be interfaced to the LNAV via K6-BT or IOIO? I have never used any of these products, but usually K6Bt and IOIO works just like a cable would. |
LPV versus LNAV/VNAV versus LNAV+V | Wyatt Emmerich[_2_] | Instrument Flight Rules | 6 | December 17th 07 01:38 AM |
Almost an LNav | Steve Leonard | Soaring | 0 | October 16th 06 11:48 PM |
Almost an LNAV | Fish | Soaring | 0 | October 16th 06 12:24 PM |
LNAV preferable over LNAV/VNAV | [email protected] | Instrument Flight Rules | 4 | October 16th 05 06:34 PM |
LNav | Gregg Leslie | Soaring | 1 | May 22nd 05 06:23 AM |
