We don't need no steenkeeng one-man rig
Old March 20th 13, 07:44 PM posted to rec.aviation.soaring
Bill D
Default We don't need no steenkeeng one-man rig
On Wednesday, March 20, 2013 10:04:44 AM UTC-6, Dan Marotta wrote:
What??? The 1,800 lb wing?
I used to be the only one who *didn't* disappear when Dave R. got his LAK-12
fuselage out of the trailer... So I moved!
"Tom K (ES)" wrote in message
Reminds me of my Lak-12...
That P-47 wing had a self-sealing fuel tank, 4, .50 cal gun mounts with ammunition trays and numerous hard points for bombs and rockets. It also had a main gear leg to support all that weight. The fuselage had pilot armor and heavy vacuum tube avionics. "Civilianized" WWII fighters often weighed a ton less than the GI versions after they were stripped of the mil-stuff.
I was surprised to see so few men lifting the propeller. Those had steel blades with silver solder contouring the airfoil. They were seriously heavy.
Old March 20th 13, 08:42 PM posted to rec.aviation.soaring
Ralph Jones[_3_]
On Wed, 20 Mar 2013 12:44:01 -0700 (PDT), Bill D
[snip]
About 10,000 lb empty, 17,000+ MGTOW. Actually the guns, which
accounted for about 350 lb per wing, wouldn't have been installed
until after assembly.
About 400 lb, IIRC.
Old March 20th 13, 10:12 PM posted to rec.aviation.soaring
Bill D
Yep. I tried to say just the mounting hardware not the guns themselves but I wasn't clear. The gun mounting hardware is heavy.
I found a reference saying each P-47 blade weighed 110 Lbs so maybe 500 lbs including the hub. That's still a lot for those guys to be lifting as high as they did. Greatest generation indeed.
Old March 21st 13, 04:45 PM posted to rec.aviation.soaring
kirk.stant
On Wednesday, March 20, 2013 8:44:01 PM UTC+1, Bill D wrote:
That P-47 wing had a self-sealing fuel tank, 4, .50 cal gun mounts with ammunition trays and numerous hard points for bombs and rockets. It also had a main gear leg to support all that weight. The fuselage had pilot armor and heavy vacuum tube avionics. "Civilianized" WWII fighters often weighed a ton less than the GI versions after they were stripped of the mil-stuff..
Minor detail - P-47s didn't get internal wing tanks until the late-war P-47N model. If this is a C, it wouldn't even have wing bomb/drop tank racks.
Still a big hunk of metal!
Kirk
66
