Is the 787 a failure ?
Old March 22nd 13, 08:54 PM posted to rec.aviation.piloting,rec.crafts.metalworking,rec.aviation.military,talk.politics.misc,alt.society.labor-unions
Default Is the 787 a failure ?
On Fri, 22 Mar 2013 08:07:19 -0600, Daryl
On 3/22/2013 7:22 AM, Jim Wilkins wrote:
"Daryl" wrote in message
...I have never had a case break open on an AGM. Daryl
Then you haven't looked very hard.
http://nissandiesel.dyndns.org/viewt...60ab1 12d039d
"Problem: APC UPSs sometimes have a float charge voltage that is too
high and tends to cook batteries. Here's a pair of gel/AGM batteries
from a SUA1000 (not an XL) that have swollen so badly that I had to
disassemble the case and pry the batteries out of the metal cage: "
And you haven't seen a burst case either. Bulging, deformed, etc. case
but the juice is contained in the case.
DAryl
I've had them split from top to bottom on both ends - but they are a
"dry" battery. All of the liquid is absorbed in the mat - and by the
time they split they are generally baked dry anyway.
Old March 22nd 13, 09:18 PM posted to rec.aviation.piloting,rec.crafts.metalworking,rec.aviation.military,talk.politics.misc,alt.society.labor-unions
Daryl[_2_]
DAryl
I was talking about accidentally damaging the case on a good battery.
They will leak if you puncture the case. You are right, many are
already cooked and have that ozone smell about them.
Daryl
ATC failure in Memphis Mxsmanic Piloting 77 October 11th 07 03:50 PM
The Failure of FAA Diversity FAA Civil Rights Piloting 35 October 9th 07 06:32 PM
The FAA Failure FAA Civil Rights Instrument Flight Rules 0 October 8th 07 05:57 PM
Failure #10 Capt.Doug Piloting 7 April 13th 05 02:49 AM
Another Bush Failure WalterM140 Military Aviation 8 July 3rd 04 02:23 AM
