Is the 787 a failure ?
Old March 22nd 13, 10:16 PM posted to rec.aviation.piloting,rec.crafts.metalworking,rec.aviation.military,talk.politics.misc,alt.society.labor-unions
Jim Wilkins[_2_]
Default Is the 787 a failure ?
"Daryl" wrote in message
On 3/22/2013 3:00 PM, Jim Wilkins wrote:
http://www.insightcentral.net/encycl...enbattery.html
You believe everything you read? Here is a quote from your very
own Cite:
"Its operating temperature range is -30C degrees ~ +60C degrees."
I can tell you (but you won't listen) that if you operate that
battery at anywhere near 10 degree or less in F, well above the -30C
rating, you will be damaging your battery on a daily basis. This is
why Tesla includes a battery heating blanket and an Air Conditioner
for it's battery compartment. Otherwise, you have cells that are
going to be damaged until, one day, you won't be able to get to the
local quick stop and back.
Daryl
Have you been snorting leaded hi-test again? Try to tame those demons;
it's only an example of a D sized battery in a car.
jsw
ATC failure in Memphis Mxsmanic Piloting 77 October 11th 07 03:50 PM
The Failure of FAA Diversity FAA Civil Rights Piloting 35 October 9th 07 06:32 PM
The FAA Failure FAA Civil Rights Instrument Flight Rules 0 October 8th 07 05:57 PM
Failure #10 Capt.Doug Piloting 7 April 13th 05 02:49 AM
Another Bush Failure WalterM140 Military Aviation 8 July 3rd 04 02:23 AM
