"Michael A. Terrell" wrote in message
... wrote: VERY common problem on "A Piece of Crap" UPS systems (as well as some cheaper ones) but when they split they don't leak. Their battery float voltage can be adjusted, if you don't mind fussing with them and know what to set it to. http://www.jjoseph.org/notes/apc_sma..._float_voltage they are designed to recharge quickly so they are ready for the next minor outage. That way they can use a smaller battery and sell them at a price that most users can afford. I have small, cheap Conext and Newpoint UPSs that take half a day to recharge after a run time test. IIRC they draw about 25W from the AC line when fully discharged. jsw |
![]() Jim Wilkins wrote: "Michael A. Terrell" wrote in message ... wrote: VERY common problem on "A Piece of Crap" UPS systems (as well as some cheaper ones) but when they split they don't leak. Their battery float voltage can be adjusted, if you don't mind fussing with them and know what to set it to. http://www.jjoseph.org/notes/apc_sma..._float_voltage I get five year life out of the steel cased APC UPS without modifications, and I have only bought one new. that was 14 years ago. Since then I have accumulated dozens of free units that work when you replace the battery. I have small, cheap Conext and Newpoint UPSs that take half a day to recharge after a run time test. IIRC they draw about 25W from the AC line when fully discharged. -- Politicians should only get paid if the budget is balanced, and there is enough left over to pay them. Sometimes Friday is just the fifth Monday of the week. ![]() |
| Part of the lithium-ion safety problem, says Elton Cairns, | a faculty senior scientist at Lawrence Berkeley National | Laboratory, in California, involves the electrolytes in the | batteries. "We're using mixtures of organic solvents that | are quite flammable and quite volatile," he says of today's | lithium-ion electrolytes. "In my view, that's just asking | for trouble." And with enough heat, oxygen gets liberated | from a battery's metal-oxide anode. "There you've got all | the makings of a fire," he says. And a flame front that | doesn't need anything outside the battery to sustain itself | is very hard to extinguish. That's why lithium-ion battery | fires can get so big (like the one that knocked out a U.S. | Navy minisub in 2008), he says. | ... http://spectrum.ieee.org/green-tech/fuel-cells/can-signal-processing-stop-battery-fires | ... | The Advanced SEAL Delivery System (ASDS) submersible | suffered major damage during a fire Nov. 9 while the craft | was recharging its lithium-ion batteries at a special base | in Pearl Harbor, Hawaii. No one was severely hurt in the | accident, but the fire burned for several hours before it | was extinguished. | | Although an investigation still hasn't determined what | caused the fire, the Navy estimates repairs to the 60-ton | craft would cost $237 million, or $180 million more than | the craft's operating budget, and take nearly three years | to complete. | ... http://www.navytimes.com/news/2009/07/navy_seal_minisub_072709w/ --bks |
| Boeing today conducted a flight test on LN86, the aircraft | being used for 787 tests, which the company says were | unrelated to a fix for the aircraft's lithium-ion batteries. | | The aircraft, also known by its Boeing production | designation as ZA272, originally was expected to make a | test flight on March 30, but for unknown reasons this was | cancelled. Boeing says the "flight is unrelated to the | ongoing 787 battery certification testing. The battery | certification demonstration flight will take place in the | coming days." | | The airframer last flew ZA272 when it conducted a | functional test flight on March 25. | | The interim testing appears to be focused on verifying the | functionality of specific systems that could play a key | role in the upcoming battery demonstration flight, as well | as other electrical systems unrelated to the battery | modification. A revised power panel design was expected to | be tested as part of the canceled March 30 flight from | Paine Field at Boeing's Everett, Wash., production facility. | | The power panel has been the source of early in-service | issues with the 787, as revealed by launch operator All | Nippon Airways, which indicated the unit had been the cause | of erroneous error messages on the engine indicating and | crew alerting system during events in March, April and June | 2012. Investigators found that a short in one of the power | panel circuit boards caused the April event. | ... http://www.aviationweek.com/Article.aspx?id=/article-xml/awx_04_01_2013_p0-564734.xml --bks |
| Don't expect FAA certification of Boeing's lithium-ion | battery fix for the 787 Dreamliner any sooner than April | 24, the end of a planned two-day "investigative hearing" on | the batteries by the National Transportation Safety Board. | | That's partly because the Federal Aviation Administration, | and its process for certifying the Dreamliner's troubled | battery system, will on the agenda for the hearing. | ... http://www.bizjournals.com/seattle/news/2013/04/02/ntsb-to-grill-witnesses-on-787.html --bks |
| A U.S. Senate committee is hosting a hearing to discuss | ongoing investigations into battery issues aboard the | Boeing 787. | | The Committee on Commerce, Science and Transportation has | scheduled the hearing for April 16, when the committee will | also hear about the Federal Aviation Administration's | efforts to implement safety provisions in FAA | authorizations. | | The committee will receive testimony from Michael Huerta, | administrator of the FAA; Deborah Hersman, chairman of the | National Transportation Safety Board; Gerald Dillingham, | director of civil aviation issues for the Government | Accountability Office; and Jeffery Guzzetti, assistant | inspector general for the Department of Transportation | Office of Inspector General. | ... http://www.gsabusiness.com/news/47258-u-s-senate-committee-to-hear-update-on-boeing-787-investigation?rss=0 --bks |
| Boeing Co. (BA)'s effort to get its troubled 787 Dreamliner | back in the air is headed for a challenging final hurdle: | It needs approval from the U.S. agency that's already been | burned by signing off on the plane's safety. | ... | The FAA isn't discussing its plans for deciding whether the | battery fix is satisfactory beyond saying that it won't | sign off on the Dreamliner's return to commercial flight | until the new battery system is deemed safe, according to | Laura Brown, a spokeswoman. She declined to comment on | whether the FAA is under any political pressure. | | The FAA's role in approving the cells for the Dreamliner in | 2007 will be the focus of a two-day NTSB hearing starting | April 23. The batteries were certified under "special | conditions," which are rules the FAA creates for new | technology. | | Another NTSB hearing starts today on the use of lithium-ion | batteries in transportation, and next week, the Dreamliner | probably will come up when the Senate Commerce, Science and | Transportation Committee holds a hearing to discuss the | FAA's progress on safety initiatives. | ... | [Transportation Secretary] LaHood, 67, a former seven-term | Republican member of the U.S. House of Representatives from | Illinois, has played a prominent role since the | Dreamliner's batteries came under scrutiny with a Jan. 7 | fire on a Japan Airlines 787. | | At a Jan. 11 news conference, he and FAA chief Michael | Huerta declared the plane safe. Less than a week afterward, | an ANA 787's battery began smoldering and spewing vapor | above Japan, prompting an emergency landing and then the | grounding. | | LaHood's involvement in the 787 decision escalates pressure | on the FAA, said John Nance, a Seattle-based | aviation-safety consultant and former commercial pilot. | ... http://www.bloomberg.com/news/2013-04-10/boeing-faces-last-hurdle-for-dreamliner-with-no-rush-faa.html --bks |
ATC failure in Memphis | Mxsmanic | Piloting | 77 | October 11th 07 03:50 PM |
The Failure of FAA Diversity | FAA Civil Rights | Piloting | 35 | October 9th 07 06:32 PM |
The FAA Failure | FAA Civil Rights | Instrument Flight Rules | 0 | October 8th 07 05:57 PM |
Failure #10 | Capt.Doug | Piloting | 7 | April 13th 05 02:49 AM |
Another Bush Failure | WalterM140 | Military Aviation | 8 | July 3rd 04 02:23 AM |
