Power FLARM battery temperature
Old March 26th 13, 12:32 AM posted to rec.aviation.soaring
Andy[_1_]
Default Power FLARM battery temperature
On Monday, March 25, 2013 3:23:52 PM UTC-7, Andy wrote:
The manual is clear on this - "The battery type must be set under the settings menu. Never use disposable batteries when the battery type is set to “rechargeable”." There is no requirement to remove non-rechargeable batteries when connected to an external power source as long as the correct battery type has been selected in the menu! Andy
Well it seemed clear enough from that reference but elsewhere it says this:
"The integrtated charging circuit does not know about the battery setting. It will attempt to charge any type of battery...."
One would be tempted to ask why the changing circuit doesn't know about the type of battery when the user has entered that information. How hard would it have been to disable the charger based on specified battery type? Why does the device need to know the battery type if not for charging protection?
Andy
Power Flarm Display SteveB_Z5 Soaring 64 March 25th 13 08:17 PM
Power FLARM as logger Lucky812 Soaring 27 December 7th 12 02:13 PM
US Power FLARM Antennas Andy[_1_] Soaring 13 June 21st 12 07:34 AM
Power FLARM deliveries? Andy[_1_] Soaring 1 June 5th 12 01:33 PM
Power FLARM question Kimmo Hytoenen Soaring 26 March 23rd 12 04:28 AM
