Hi to all.
I'm electronic technician and i start to repair some equipments for gliders and planes.So i have a problem with a Becker AR3201. The problem is when you press the PTT to talk or you receive a signal you hear at the headset or at the speakers a noise like the noise from alternator. I try to install a power line filter but without any success. I try with the engine not running (only with the battery) and the problem is still presents. Any idea what happen ??? Thanks for any help. Lazaros Greece |
At 10:54 24 March 2013, Lazarost wrote:
Hi to all. I'm electronic technician and i start to repair some equipments for gliders and planes.So i have a problem with a Becker AR3201. The problem is when you press the PTT to talk or you receive a signal you hear at the headset or at the speakers a noise like the noise from alternator. I try to install a power line filter but without any success. I try with the engine not running (only with the battery) and the problem is still presents. Any idea what happen ??? Thanks for any help. Lazaros Greece -- Lazarost I know next to nothing about radios, but could it be that the squelch needs turning down? On the 3201 there is an adjustment screw that you get at through the lowest of 3 holes in the RH side of the casing. Dave |
Check your grounding. Noise in radios is generally caused by poor grounding paths. Run a separate lead from the radio ground to the negative of the battery. If it clears it up then you should troubleshoot the grounding lead. Good luck.
Quote:
I place the unit on my desk and checking with a microscope for any damage. So if i find something i post it here for reference to all. Thanks for everything !! |
| Thread Tools | |
| Display Modes | |
| Becker AR3201 | [email protected] | Soaring | 4 | April 7th 09 12:15 AM |
| AR3201 Harness? | noel.wade | Soaring | 13 | March 10th 09 03:23 PM |
| Wanted: Becker AR3201 | Ira Blieden | Soaring | 0 | December 14th 06 07:28 PM |
| Looking for a Becker AR3201 | Ira Blieden | Soaring | 0 | December 8th 06 02:38 PM |
| Problems with Becker | [email protected] | Soaring | 6 | August 26th 05 10:33 AM |
