Flanker vs F-15
Old March 25th 04, 08:44 AM
Boomer
yes Flankers have a switch which over rides the FBW limits, that's the only
way they can do the "Cobra" manuever. As I recall F-15s started out with
hydro controls with FBW as back up, then later models went fully fly by
wire.
Curiosity killed the cat, and I'm gonna find out why!
"Michael Kelly" wrote in message
m...
John Mullen wrote:
The Su has a pull-through fuction on the fbw ISTR. Might be a factor?
Probably not since the the F-15C isn't FBW and only has an overload
warning function. You can over G a F-15C.
Michael Kelly, Bone Maintainer
John
Old March 26th 04, 01:41 AM
Mary Shafer
On Thu, 25 Mar 2004 02:44:04 -0600, "Boomer"
wire.
The F-15 started as conventional with conventional backup and an
analog FCS. It eventually went to a digital FCS, but not to FBW.
The E might be FBW, but the A-D aren't.
Mary
Mary Shafer Retired aerospace research engineer
Old March 26th 04, 09:25 PM
Steve
Or you can simply apply an extra 33lb of stick force.
Steve.
Old March 26th 04, 09:27 PM
Tarver Engineering
"Steve" wrote in message
only
That is a lot, the F/A-18 breaks out at 20 lbs.
Old March 28th 04, 02:05 AM
monkey
"Tarver Engineering" wrote in message ...
only
Not true - you are confusing this with aoa feedback in the stick above
20 alpha -to get more g than the programmed limiter (usually 7.5) you
must engage the paddle switch, which will then give you 33% more g.
Old March 28th 04, 02:34 AM
Tarver Engineering
"monkey" wrote in message
om...
only
I am refering to the force required to move the stick. My F-18 (AV6) had a
swich on the left panel to cut out the FCS much like the MiG.
Old March 28th 04, 08:43 PM
monkey
om...
only
move the stick for what?
Old March 28th 04, 08:56 PM
Tarver Engineering
m...
om...
that's
only
had a
The stick moves to operate the cable actuated system control system.
Do you know the airplane at all, monkey sock?
OT-ish Su27 Flanker fans *might* enjoy... Andrew MacPherson Military Aviation 0 February 1st 04 11:33 AM
F-22 Comparison robert arndt Military Aviation 39 December 4th 03 04:25 PM
[New WebSite] Su-27 Flanker Benoit Military Aviation 0 November 11th 03 04:54 PM
Su-27SK(Upgraded), Su-27KUB & new Flanker book Thomas J. Paladino Jr. Military Aviation 6 July 28th 03 07:53 PM
RIAT Fairford Reviews John Cook Military Aviation 4 July 21st 03 07:36 PM
