New Racing Class in the US for 2014?
Old April 2nd 13, 10:45 PM posted to rec.aviation.soaring
Default New Racing Class in the US for 2014?
On Tuesday, April 2, 2013 4:34:49 PM UTC-4, Tony wrote:
Regarding the LeMonns start...early 1-26 Regattas and Championships usually featured a rigging contest, especially the ones held at Harris Hill. Trailers were positioned on one side of the runway and crews on the other. I don't know if there was a limit on # of people but I'm pretty sure that 3 or 4 was common. I remember reading that the Soaring Dutchmen were well known as being the team to beat, rigging a 1-26 to flyable condition in less than 5 minutes. Pretty sure they trailered with the tail on which is kinda cheating.
Record for assembly was by the Dutchmen in just over 2 1/2 minutes and they did put the tail on.
UH
Old April 2nd 13, 10:55 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
On Tuesday, April 2, 2013 4:45:35 PM UTC-5, wrote:
Record for assembly was by the Dutchmen in just over 2 1/2 minutes and they did put the tail on. UH
Not too shabby for three bolts and two control connections per wing! (assuming this is pre-D model 1-26) And, what, three bolts and the pushrod for the tail?
Steve
Old April 2nd 13, 11:39 PM posted to rec.aviation.soaring
Tony[_5_]
Steve
wow 2.5 minutes is impressive. Thats NASCAR pit crew style analysis on getting the job done.
Speaking of NASCAR will the LeMonns rules give the CD the option to call a NASCAR day where if post flight analysis of your trace shows any complete 360 to the right you get a 1000 point penalty?
Old April 2nd 13, 11:43 PM posted to rec.aviation.soaring
Tony[_5_]
Steve
oh another twist on the Endurance task. if you have a class in the endurance task that flies with water ballast, a calibrated leak must be installed in the system so that after about 1.5 laps you'll be out of water. then the decision must be made whether to pit for more water or try to win the race on "old tires"
Old April 3rd 13, 06:54 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
On Tuesday, April 2, 2013 5:43:47 PM UTC-5, Tony wrote:
Thats NASCAR pit crew style analysis on getting the job done. Speaking of NASCAR will the LeMonns rules give the CD the option to call a NASCAR day where if post flight analysis of your trace shows any complete 360 to the right you get a 1000 point penalty? oh another twist on the Endurance task. if you have a class in the endurance task that flies with water ballast, a calibrated leak must be installed in the system so that after about 1.5 laps you'll be out of water. then the decision must be made whether to pit for more water or try to win the race on "old tires".
Hitler will not be approved by the RC as a CD, so there will be no penalties for turning left. Or right.
No leaks will be induced in any ballast systems in a LeMonns glider. If it was that low cost to start with, there probably are already leaks in any ballast system that might be installed.
WGC 2014 Finland Car+crew available [email protected] Soaring 1 August 8th 13 06:06 PM
USA Nationals Schedule for 2014 and 2015 John Godfrey (QT)[_2_] Soaring 17 March 29th 13 02:42 PM
Potential Club Class (US Sports Class) World Team Selection Policy Changes John Godfrey (QT)[_2_] Soaring 84 September 27th 10 08:03 PM
Art of Racing, concluded - Langelle - Glen Martin Racing.jpg (1/1) Mitchell Holman[_4_] Aviation Photos 0 February 28th 10 08:22 PM
The Art of Racing - Corning - Beach Racing Oldfield.jpg (1/1) Mitchell Holman[_4_] Aviation Photos 0 February 27th 10 12:42 PM
