Mech vario - Static vs TE?
Old April 6th 13, 06:05 PM posted to rec.aviation.soaring
Default Mech vario - Static vs TE?
I use to have a Borgelt B-50 in my HP-14. It was installed as prescribed in
the B-50 manual.
http://www.borgeltinstruments.com/B50man.pdf
" The T-piece in the T.E. line should be as close as possible to the T.E.
probe although in practice it has been found that if the T.E.
line is split under the pilot's seat, further aft behind the seat or near
the trailing edge of the wing no problems will result."
With the turtle-back off the '14 it was easy to put the T-piece in the
tail-cone aft of the trailing edge of the wing.
http://tinyurl.com/N990-6F
"Kevin Christner" wrote in message
I would recommend splitting the TE line as far back from the
instrument as possible (6 feet is probably plenty, but more doesn't
hurt) to avoid interference. Otherwise the varios seem to "play" with
each other and you get pretty bad compensation.
2C
On Apr 5, 8:39 am, wrote:
On Thursday, April 4, 2013 9:53:00 PM UTC-4, dbrunone wrote:
Quick question -- for a mechanical vario (such as Winter), do most
people hook up the static port to the TE probe, or the static line? It
seems the TE probe would naturally compensate the vario for stick
movements, but is there a disadvantage? -- dbrunone
Connect to total energy probe.
If used with a non flow type electric variometer, connect in parallel and
with at least 6 feet of tubing from where the TE lines from the vario join
to the TE source line.
UH
Tasman Vario on Static 5Z Soaring 0 April 19th 11 01:56 AM
Tasman Vario on Static Tony[_5_] Soaring 12 April 15th 11 09:14 AM
Pilot vs Mech James Huber Home Built 0 October 20th 07 02:04 AM
Winter Mech Vario Bezel Mike Hostage Soaring 2 March 29th 05 05:42 AM
WTB: (USA) Mech Vario 57mm(2-1/4) Knots Curtl33 Soaring 7 January 24th 04 03:31 AM
