Probably right Eric. I never tried zooming in that much and it was almost a year ago since I flew the airplane that had it. Really cool stuff but I would not be able to advantage a lot with it although it would be nice in thunderstorm and rain. The radar is highly accurate and definitely shows tops, enough to confidently fly around multiple cells, etc. Also all the Garmin units that display weather are quite large so fitting it into a glider might be a challenge. Perhaps the major soaring instrument manufactures will begin building Garmin & other weather services weather into their units in the future. Would be great to simply change screens and go from soaring map to weather. Or to select weather overlay!
On Wednesday, April 10, 2013 1:34:00 PM UTC-7, Sean F (F2) wrote:
" . . . Also all the Garmin units that display weather are quite large so fitting it into a glider might be a challenge. . . ." I guess that all depends. Some Garmin GPS, Aera 560 and the previous 396, 496 (all WX capable) fit with no problem in my ASH26E. I have a 796 w/wx, and that's too big! bumper |
True. The 396/496 are awesome units but not exactly small. I used to have one in my little liberty XL2. Can easily be mounted flush in the panel with an OEM panel mounting plate. Used on Enay from $450-700, respectively.
Compare/Contrast: CG hook on aerotow vs. CG hook on winch | son_of_flubber | Soaring | 37 | June 4th 12 10:40 PM |
COMPARE THIS ULTIMATE PANEL | Guy Byars[_2_] | Soaring | 40 | September 17th 09 03:24 PM |
How to compare/valuation of features | Douglas Paterson | Owning | 10 | January 28th 07 10:14 PM |
And they say the automated Weather Station problems "ASOS" are insignificant because only light aircraft need Weather Observations and forecasts... | Roy | Piloting | 4 | July 12th 03 04:03 PM |
