On 4/24/2013 12:43 PM, soartech wrote:
and FM suffers from capture effect/overtalk issues (why we use AM to start with). Darryl Darryl, Please explain these terms. I always thought aviation used the outdated AM because that's what they started with many years ago. After having used 2 meter FM radios for many years I find them to be vastly superior to aircraft band AM radios. The advantage of AM is that when two people talk at once you hear them both. With FM, you get the strongest signal or, when both signals are nearly equal in strength, you hear neither. I'll take AM for aviation radio. For ham VHF/UHF, it's FM/SSB/digital. :-) Tony "6N", W1DYS |
On Wednesday, April 24, 2013 4:31:35 PM UTC-7, Tony V wrote:
On 4/24/2013 12:43 PM, soartech wrote: and FM suffers from capture effect/overtalk issues (why we use AM to start with). Darryl Darryl, Please explain these terms. I always thought aviation used the outdated AM because that's what they started with many years ago. After having used 2 meter FM radios for many years I find them to be vastly superior to aircraft band AM radios. The advantage of AM is that when two people talk at once you hear them both. With FM, you get the strongest signal or, when both signals are nearly equal in strength, you hear neither. I'll take AM for aviation radio. For ham VHF/UHF, it's FM/SSB/digital. :-) Tony "6N", W1DYS What he said... Darryl |
On Apr 24, 4:31*pm, Tony V wrote:
The advantage of AM is that when two people talk at once you hear them both. With FM, you get the strongest signal or, when both signals are nearly equal in strength, you hear neither. Plus, for weak signals, AM offers better signal to noise ratio. In less technical terms, if pilot A has to really struggle to hear and understand pilot B using AM, then pilot A would not hear anything if they were using FM. Bart |
Contest Grid Spacing? | ContestID67[_2_] | Soaring | 3 | June 1st 11 03:29 AM |
Long EZ plans, Mini IMP plans, F4U Corsair plans, materials, instruments for sale | reader | Home Built | 1 | January 26th 11 01:40 AM |
Duster Plans For Sale - BJ-1b fullsize sailplane plans | WoodHawk | Soaring | 0 | April 25th 05 04:37 AM |
[igc-discuss] To change or not to change... rules ? | Denis | Soaring | 0 | February 16th 05 07:24 PM |
U$ Says Prisoners Beaten With Hand-Held Radios, NOT Clock Radios! *snicker* | JStONGE123 | Military Aviation | 1 | May 11th 04 06:22 AM |
