FAA Plans to Change to Radios with 8.33 MHz spacing?
Old April 25th 13, 05:51 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default FAA Plans to Change to Radios with 8.33 MHz spacing?
On 4/24/2013 12:53 PM, Mike the Strike wrote:
Unfortunately those "unused" 8.3kHz channels don't actually exist -
they are already occupied by the existing 25kHz channels. Also any
radio you use to transmit here in the USA has to be type approved and
current approval doesn't include the 8.3kHz units.
I don't understand the claim of "not approved" status: quite a few 8.3
kHz spacing units are available for sale in this country, including
Becker AR6201 and MGL V6 (the unit I use). Are these illegal to use on
the standard 25 kHz spacings?
email me)
  #32
Old April 25th 13, 05:23 PM posted to rec.aviation.soaring
Mike the Strike
Radios for sale in the USA should have switchable 25kHz/8.3kHz spacing so that they can be used in areas where either standard is used - but they are only currently legal to use in the USA with 25kHz spacing.
Mike
  #33
Old April 26th 13, 10:28 PM posted to rec.aviation.soaring
Sean F (F2)
On Wednesday, April 24, 2013 3:53:34 PM UTC-4, Mike the Strike wrote:
Unfortunately those "unused" 8.3kHz channels don't actually exist - they are already occupied by the existing 25kHz channels. Also any radio you use to transmit here in the USA has to be type approved and current approval doesn't include the 8.3kHz units.
Sorry!
poop!
  #34
Old April 27th 13, 12:46 AM posted to rec.aviation.soaring
Bart[_4_]
I would be surprised if a "25kHz" radio actually used more than 4kHz
on each side of the carrier, interfering with the "unsused" channels.
BUT, I would be much less surprised if a "25 kHz" radio, especially an
older one, was adversely affected by a transmission made 8.33 kHz
away.
Bart
  #35
Old April 27th 13, 12:55 AM posted to rec.aviation.soaring
Bart[_4_]
On Apr 24, 4:31*pm, Tony V wrote:
The advantage of AM is that when two people talk at once you hear them
both. With FM, you get the strongest signal or, when both signals are
nearly equal in strength, you hear neither.
Plus, for weak signals, AM offers better signal to noise ratio. In
less technical terms, if pilot A has to really struggle to hear and
understand pilot B using AM, then pilot A would not hear anything if
they were using FM.
Bart
Contest Grid Spacing? ContestID67[_2_] Soaring 3 June 1st 11 03:29 AM
Long EZ plans, Mini IMP plans, F4U Corsair plans, materials, instruments for sale reader Home Built 1 January 26th 11 01:40 AM
Duster Plans For Sale - BJ-1b fullsize sailplane plans WoodHawk Soaring 0 April 25th 05 04:37 AM
[igc-discuss] To change or not to change... rules ? Denis Soaring 0 February 16th 05 07:24 PM
U$ Says Prisoners Beaten With Hand-Held Radios, NOT Clock Radios! *snicker* JStONGE123 Military Aviation 1 May 11th 04 06:22 AM
