OAT on LX-7000
Old May 7th 13, 01:44 PM posted to rec.aviation.soaring
Paul Remde
Default OAT on LX-7000
Hi John,
If I remember my engineering courses correctly, cutting and reconnecting the
leads of a temperature probe is not recommended. The temperature sensing
depends on the slight difference in the metals in the 2 wires and cutting
and especially soldering them together again, or connecting them with metal
connectors will change how well they work and will give them an offset. I
imagine the LX7000 was calibrated to the sensor at the factory. It would
need to be recalibrated if you cut it and solder it together or use
connectors.
That said, at least one soaring instrument manufacturer is convinced that
the temperature sensor is not necessary. They are often installed in
locations that lead to very inaccurate readings - such as in the air vent.
Those inaccuracies lead to worse information then you would get without a
temperature sensor at all.
Best Regards,
Paul Remde
__________________________
"C-FFKQ (42)" wrote in message
Probably a dumb question... and I think I know the answer... but...
May I cut the OAT wires and insert a two-pin connector so that I may place
the OAT sensor in a good location in my ship and still easily remove the
panel?
Looking at the schematics, it's just 2 wires leading to the sensor, so I
would think it's okay, but my knowledge of electronics is rather limited
(and I'm rather ham-fisted).
TIA,
John
Old May 7th 13, 03:25 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
It's very unlikely any instrument is using thermocouples for temperature
sensing; instead, they use standard devices that connect with plain old
wire.
So, cut the cable, put in the connector, and you are good to go. Be sure
the each sensor wire is connected to the same wire from the instrument
it was connected to previously.
On 5/7/2013 5:44 AM, Paul Remde wrote:
Hi John,
the leads of a temperature probe is not recommended. The temperature
sensing depends on the slight difference in the metals in the 2 wires
and cutting and especially soldering them together again, or connecting
them with metal connectors will change how well they work and will give
them an offset. I imagine the LX7000 was calibrated to the sensor at
the factory. It would need to be recalibrated if you cut it and solder
it together or use connectors.
that the temperature sensor is not necessary. They are often installed
in locations that lead to very inaccurate readings - such as in the air
vent. Those inaccuracies lead to worse information then you would get
without a temperature sensor at all.
Best Regards,
Paul Remde
place the OAT sensor in a good location in my ship and still easily
remove the panel?
TIA,
John
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what
you need to know tinyurl.com/yfs7tnz
Will buy: LX 7000, LX7007 or LX8000 Erich Soaring 0 December 6th 09 10:54 AM
LX 7000 igc pro to winpilot Stuart Kinnear Soaring 7 May 4th 05 02:29 PM
how to homebrew a 7000-psi mechanical press? Brian Whatcott Home Built 0 April 23rd 05 07:39 PM
FS : GPS Trimble TLN 2000 + Moving Map ARGUS 7000 PA34 F-GFTF Aviation Marketplace 0 January 9th 05 08:42 PM
Ilec SN 10 or LX 7000 Dave Kuchenbecker Soaring 12 October 23rd 03 05:05 AM
