Momentary GPS data dropouts with PowerFLARM to SN10A to Oudie2 setup
Old May 7th 13, 03:06 PM posted to rec.aviation.soaring
Craig R.
Default Momentary GPS data dropouts with PowerFLARM to SN10A to Oudie2 setup
On Monday, May 6, 2013 12:53:13 PM UTC-7, kirk.stant wrote:
I made a couple of flights yesterday with a new setup that links a PowerFLARM brick (2.79/3.1/Flarmnet loaded) to an SN10B (2.37, PDA, FLARM, 19200 selected) passing Flarm, GPS, and vario data to an Oudie2.
All worked exactly as expected EXCEPT that randomly during flight, at irregular intervals, I would get a momentary GPS dropout in the Oudie, indicated by either a PRIMARY GPS BAD followed immediately by a PRIMARY GPS OK caution on the Oudie, or more frequently just the PRIMARY GPS OK caution.
Kirk, I may be wrong here, but I'm pretty confident that it is the 2.37 SN10 software causing the issue. I have the brick and SN10 combo (no Oudie... yet) and I upgraded from 2.36 this March. I am still running the 2.4 PF brick software. I experienced the same irregular drops on every flight so far after the 2.37 upgrade. I had zero drops last year running 2.36. Quite annoying. Fortunately, I have other flight recorders for my trace. It looks like I'll be loading the 2.38 as soon as it's available.
Craig
New Naviter Oudie2 Lite Paul Remde Soaring 0 December 7th 12 03:26 AM
Oudie2 Units in Stock Paul Remde Soaring 0 August 30th 12 03:14 PM
Oudie2's available again in the USA - Upgrades also available Paul Remde Soaring 0 August 20th 12 09:32 PM
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
Oudie2 units now shipping Paul Remde Soaring 3 April 30th 12 08:51 PM
