Too fast vs too slow
Old May 8th 13, 09:13 AM posted to rec.aviation.soaring
Default Too fast vs too slow
W dniu środa, 8 maja 2013 10:02:44 UTC+2 użytkownik Roel Baardman napisał:
If you look at the lines on the bottom of this graph: http://soaringcafe.wpengine.netdna-c...io-Polars1.jpg You will see the glide ratio plotted versus the speed. For every speed this diagram gives you the glide ratio for that speed. If you then look at the optimal glide point, that is the point where graphs reach their lowest point (the Y-axis is on the right for these graphs), you see that on both sides of this peak the line has roughly the same slope. This leads me to conclude that it does not really matter, for this particular aircraft at least.
Bad example - compare this polar with real Concordia performance from igc file ;-)
Your opinion would have been correct if the polar was a straight line, but it isn't...
Old May 8th 13, 01:29 PM posted to rec.aviation.soaring
Roel Baardman
I was trying to say that, since the shape of the curve on both sides of the theoretical optimal point is symmetric, it does not really matter. Optimal +10kts gives roughly the same L/D as Optimal
-10kts.
Furthermore, I think John Cochrane hits the nail on the head here (again).
Roel
Old May 8th 13, 01:59 PM posted to rec.aviation.soaring
Jeremy Keeling
but it isn't...
Optimal
-10kts.
(again).
Roel
But the polar curve is not symmetric about the point of intersection with
the tangent that passes through the origin, ie the maximum glide - we're
not talking about min sink here.
Infact, I bet you will achieve a better glide ratio if you fly 10 knots
slower than best glide than 10 knots faster (in still air).
Old May 8th 13, 03:37 PM posted to rec.aviation.soaring
Roel Baardman
we're not talking about min sink here.
This sums up my error quite nicely. Thanks for correcting me!
Old May 8th 13, 04:17 PM posted to rec.aviation.soaring
WAVEGURU
I think we are all missing a big part of the equation...
How bad do you have to pee?
Boggs
Slow Down, Speed up Robert Gaines[_2_] Soaring 21 April 17th 09 09:45 AM
AI sometimes slow to come up to speed Peter R.[_2_] Owning 4 April 12th 08 10:30 PM
Being towed too slow? Steve Leonard Soaring 23 November 21st 07 11:19 PM
why so slow??!! Heino & Deanne Weisberg Home Built 6 November 6th 05 06:22 PM
Flying Slow [email protected] Piloting 61 January 17th 05 05:23 PM
