On Friday, May 10, 2013 7:21:55 AM UTC-6, wrote:
I just don't see the need for winching to 2-3k feet in a glider and if you disagree you probably have some thermaling to learn. Herb Depends on the purpose of the flight. Early morning or late evening student training flights can benefit from higher launches. |
Don is right in thinking that there should be one person in charge of the
launch. Unfortunately the person he thinks should be in charge is at the wrong end of the cable. With high powered winches driving through auto transmission (Skylaunch) the pilot has little control over the speed of launch, he just has to accept what the winch driver gives him. With a launch system that provides cable tension, by whatever control system is used, the speed is under control of the pilot. Ease off on the stick speed increases, ease back speed reduces, just like in normal flight. I've launched on both in the UK & I know which I prefer PF At 13:52 10 May 2013, Bill D wrote: On Friday, May 10, 2013 7:21:55 AM UTC-6, wrote: I just don't see the need for winching to 2-3k feet in a glider and if you disagree you probably have some thermaling to learn. Herb Depends on the purpose of the flight. Early morning or late evening student training flights can benefit from higher launches. |
On Friday, May 10, 2013 8:42:39 AM UTC-6, Peter F wrote:
Don is right in thinking that there should be one person in charge of the launch. Unfortunately the person he thinks should be in charge is at the wrong end of the cable. You are correct, it's much better to have the pilot control airspeed with pitch. However, for this to happen, the winch has to control rope tension accurately as a percentage of glider weight. Control is divided where pilot controls airspeed and winch controls tension. This means Gary is right to control rope tension with his payout winch. |
At 14:55 10 May 2013, Bill D wrote:
On Friday, May 10, 2013 8:42:39 AM UTC-6, Peter F wrote: Don is right in thinking that there should be one person in charge of the= launch. Unfortunately the person he thinks should be in charge is at the wrong en= d of the cable. You are correct, it's much better to have the pilot control airspeed with p= itch. However, for this to happen, the winch has to control rope tension a= ccurately as a percentage of glider weight. Control is divided where pilot= controls airspeed and winch controls tension. This means Gary is right to= control rope tension with his payout winch. No, I said there should be one person with total control of the winch, just the same as the number of people in command of a glider. Would you fly an airplane where one pilot had control of the stick pulling back and another pilot was in control of pushing it forwards? The person in charge of the launch is always the pilot of the glider who has absolute control of the airspeed at all times via the stick and yellow knob. From a 2500' run we get 1000 ft winch launches in still air. We are cleared and capable of winching to 3000ft but seldom do, using a standard Skylaunch winch. Average winch launch at our site using the standard runs is 1500ft. |
On Friday, May 10, 2013 9:36:02 AM UTC-6, Don Johnstone wrote:
At 14:55 10 May 2013, Bill D wrote: On Friday, May 10, 2013 8:42:39 AM UTC-6, Peter F wrote: Don is right in thinking that there should be one person in charge of the= launch. Unfortunately the person he thinks should be in charge is at the wrong en= d of the cable. You are correct, it's much better to have the pilot control airspeed with p= itch. However, for this to happen, the winch has to control rope tension a= ccurately as a percentage of glider weight. Control is divided where pilot= controls airspeed and winch controls tension. This means Gary is right to= control rope tension with his payout winch. No, I said there should be one person with total control of the winch, just the same as the number of people in command of a glider. Would you fly an airplane where one pilot had control of the stick pulling back and another pilot was in control of pushing it forwards? The person in charge of the launch is always the pilot of the glider who has absolute control of the airspeed at all times via the stick and yellow knob. From a 2500' run we get 1000 ft winch launches in still air. We are cleared and capable of winching to 3000ft but seldom do, using a standard Skylaunch winch. Average winch launch at our site using the standard runs is 1500ft. That's a fuzzy analogy. A better analogy is an airplane with a flight engineer controlling the power of the engines. The engineer (think winch operator) applies whatever power the pilot asks for. The pilot then takes that power and controls airspeed with pitch attitude. |
Please describe to us a winch accident that would be the fault of the winch and not the pilot.
Boggs |
On Friday, May 10, 2013 10:25:24 AM UTC-6, Waveguru wrote:
Please describe to us a winch accident that would be the fault of the winch and not the pilot. Boggs First, Gary, let me say again I agree with your position on pilot responsibility and I would be perfectly willing to take a tow behind your payout winch. However, here's a couple of scenarios where a powerful winch can be safer than auto tow. On a calm but strongly thermic day, a tailwind gust is encountered just as the glider begins rotation into the climb. If the winch has substantial reserve power, and is controlling rope tension, it will instantly add power to help the glider maintain a safe margin over stall in the critical rotation phase. In this case, the pilot has less control over his fate than the winch. If the winch or tow car power is marginal, the glider may stall in this situation. This is why the DAeC Technical Committee guidelines set minimum power and rope speed requirements. Another scenario is a winch which balks just after the glider is airborne leaving the glider momentarily gliding at minimum controllable airspeed. The winch then "catches" and applies full power. Without the runway surface supporting the tail wheel, and if the glider's CG is well above its hook, the inertial couple effect may cause a dangerous uncommanded pitch-up. This is why the DAeC Technical Committee, in another paragraph, requires absolute smoothness in winch power without any tension oscillations or spikes in rope tension. |
Ground launch payout winch systems...Are they suitable for gliders? | [email protected] | Soaring | 13 | August 13th 14 04:30 PM |
Winch Launch Fatality | Ed Gaddy[_2_] | Soaring | 3 | June 23rd 09 11:15 PM |
Pay out winch launch to 2500ft agl.. | WAVEGURU | Soaring | 8 | June 5th 07 07:06 AM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
Winch launch | M B | Soaring | 0 | October 30th 03 07:33 PM |
